1995 Subaru Legacy Logo
Tadd Posted on Dec 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the heater blower motor located in a 95 subaru legacy
I need to check the blower motor in this car to see if there is power to it. I also need to check the switch for the motor. Has anyone had this issue and if so what did you find?
Thomas Perkins
Level 3:
  • Subaru Master 15,088 Answers
  • Posted on Dec 13, 2012
Thomas Perkins
Subaru Master
Level 3:
Answers
15088
Questions
0
Helped
3386462
Points
54869
Here's a link to the blower motor.Here's a link to the blower motor resister,it's next to the blower.Here's the the relay.Here's the switch.The Blower Motor Relay is located:Front seating area, driver side, under dash, mounted above fuse panel
2 Related Answers
Anonymous
  • 377 Answers
  • Posted on Nov 15, 2009
SOURCE: Replace heater blower motor on 1992 subaru legacy
yes that is correct, remove glovebox , metal bracket in front ( mark which way round this bracket goes it will go back wrong and glove box wont fit ) , unplug electrical plug from heater motor, unscrew 3 bolts/screws from motor replace in reverse..30 min tops..
Anonymous
  • 54 Answers
  • Posted on Jul 19, 2009
SOURCE: 1995 subaru legercy heater
there is a resistor located under the dash which controls the settings for the fan if this has overloaded or blown up the blower motor wont work
Problems heater
Are you saying the blower motor is not blowing any air? Check for power right at the blower motor first.
2004 Subaru Imrpeza Outback Sport - Where is the heater blower/motor located in this car?
Hey Tbird,here's a link to the blower motor,right by the blower motor is the blower motor resistor,you might want to check this first,if they go out then blower motor won't work,you can straight wire blower to see if works,if it doesn't then try resister,here's what it looks like.
2006 B4 Subaru Legacy A?C blower motor runs at high speed all the time when switched on
blower motors are regulated by group of resistors that cause the voltage to reduce at different amounts resulting in high to low speeds on the fan. When this fails the motors goes to high speed all the time. These are not expensive or hard to replace. Usually a plug connector and a couple of screws and around $25 will do it. These are located under the dash in the main body of the heater as they rely on air blowing over them to reduce the heat created by the resistance. the side opposite the connector will look like sifferent sizes of wire wound much like a spring to create resistance and slow the blower motor down. Once you have this out you can go to a parts store and ask for a replacement one. good luck
2answers
Where is the heater fan located
The heater blower motor is located under the dash on the passenger side.
95 subaru legacy had the blower quit about a week ago, had no power to the motor so i thought it was the relay. then the speedometer, tachometer, odometer, and temp gauge quit working. I tried to get home...
do you have battery power will the car turn over
there is a set of fuses in the engine compartment check these as many cars have a system that allows the car to run till the battery dies check your alternator
8helpful
1helpful
1helpful
Subaru a/c and heater fan doesn't work
You could have a blown fuse, bad relay, bad blower motor resistor pack, or just a bad blower motor. Start with checking your fuse to make sure you have power to you blower motor.
Fan blower stopped working
I had the same problem and Ia m working to resolve it.
You need to remove the blover under the glove box it's very easy to remove. 1) remove the glove box, 2) the metalic suport that it's hold by 4 screws and finally remove the 3 screws that holds the blower. Take it off and remove the coverplate of the motor ( 2 screws) and
check the brushes. In my case they were worn out. So you need to buy a new motor with the blower aprox $50 or try to replace the brushes.
Top Subaru Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Subaru Expert? Answer questions, earn points and help others
