Question about Sony Playstation 3 (PS3) Console
PS3 Video Connection--Lines on TV
Hello! I just got a brand new PS3, 80GB, and I hooked it up using the regular AV Controller. The TV I hooked it up to is not an HD or flatscreen TV, but is probably only 4-8 years old. It is a JVS. When I hook up the PS3 to any of the AV connections, the PS3 screen has a series of white interference lines that run up and down the screen. This does not occur with any other device hooked up to the TV (i.e. cable and a DVD player).
Is this a problem with the PS3, or the wires? Or is it possibly a compatability problem? I have not yet tried to hook up the PS3 to an HDTV that is also in my house to see if that fixes the problem. Should I try that? Like I said, the PS3 was bought brand new, and this was the first time I hooked it up, and I made sure that all of the connectors were secure. I also tried it in multiple inputs, and still the same effect.
  • Anonymous Jan 14, 2009
    I have already tried changing the PS3 video settings. Still have feedback. Any other clues on how to fix it?
  • sadie456 Jan 14, 2009
    I did try changing the video settings to the AV control. still getting the sound feedback (forgot to mention that in the first post) and the lines. Any other suggestions?
This may be due to the fact that your ps3 will be set up to hd. go into video settings when you switch it on and this should solve the problem. i had similar problems and bought a hdtv until someone pointed this out to me. however once you have experienced ps3 in hd you will not go back!!! hope this helps
Posted on Jan 13, 2009
2 Suggested Answers
cheebster
  • 39 Answers
SOURCE: No HDTV
Hi there. There might be some solution out there that would work for you, KboxMod. Here it is : To reset the display settings of the Xbox 360 console to the default settings, remove any discs from the disc tray. Turn the console off and turn it back on. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. The Xbox Dashboard resets the display settings to the default settings, and then automatically restarts the console. Note: If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller. Make sure that you use the player 1 controller when you do this. The player 1 controller will have the upper-left quadrant light illuminated. Try it a few times, some say it took a few retries to get it working. It might just need a reset of those video settings. Hope that helps, cheebster.
Posted on Jun 18, 2007
My ps3 is hooked up to a av connection tv and the settings on it is for a HD tv. so i don't have a picture and can't see my menu screen to go into the settings to change it. i need someone to guide me...
ok first u need to connect ur usb to ur controller then u need to hold ur finger on the power button let it go off 2 times then on th third time it will beep two times real fast then lift ur finger off then press reset system.make sure u have the hdmi and av cables connected so if it does not work u can repeat it over again.this will work
Mar 10, 2010 | Sony Playstation 3 (PS3) Console
PS3 hdmi connection works but not std rca AV
You must set it OFF HDMI while connected to the TV...
Feb 28, 2010 | Sony Playstation 3 (PS3) Console
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
How do you change the output setting from hdmi to the rca cable setings? I have no picture screen on my crt tv.
you have to reset the ps3 because you have it with hdmi before and the ps3 is looking for an hdmi connection is very easy and there is nothing wrong with your ps3 ok so do the follow
turn the power switch off on the back of the unit then put your finger in the on/off switch now turn the main switch on the back of the unit you will heard a first bip sound this is when your ps3 turns on ok keep your finger there in the on/off switch until you heard another bip sound now remove your finger from the on/off switch and bingo this will reset your video settings now you can see picture again using regular av and every time you use hdmi you have to do this again
Jun 05, 2009 | Sony PlayStation® 3 (80GB) Console
Powers on but nothing happens
It happened to me too. When you plug in your av cables and are ready to play, follow these steps. With your PS3 off (Red light on), Press and hold the power button on your console. (Do not use the controller to turn it on.) Keep holding the button until you hear a second beep. (it takes about 2 to 3 seconds.) You will notice your screen flickers, then your PS3 will show up on the tv. All you did was reset the PS3 display settings. You can always go back to HDMI or AV cables. Have Fun.
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
Connecting ps3 to a standard tv
Hello
I think that you should have a button on the remote which lets you switch to the auxilliary connection of the TV (it won't switch automatically). Try putting it on AV1 AV2 or AUX or such modes you have to refer to your TV manual to see how to switch exactly to the Video Line in Connection.
This should solve your problem :)
Cheers :)
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Source list for Samsung LCD TV when hooking up PS3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option. hope this helps
Dec 10, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
590 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
