Question about Asrock K8Upgrade-VM800 Motherboard
No display a pleasant day to all of you... i have a problem with my computer, i'm getting no diplay at my monitor, i already tried resseting all components still no luck, my mb is an asrock with kbu-upgrade vm800 (or k8u-upgrade.. whatever i cant seem to undestand it.. sorry), my colleague says i have to replace sumthin, but didnt told me... btw.. when i reset the components, i got a beep when there is no RAM, the only thing that i cant reset is the video card, because it is onboard, thou i tried another video card (a functional one from my other conputer) still has no display, can you please tell me what will i do? or what will i need to replace? thanks and more power...
  • jaypee masangkay Jun 13, 2007
    i already tried clearing the cmos... all i get from my monitor is the "check your signal cable" thingy.. thou my cpu fan runs, and i have a green light, no red... where will i find the cmos chip? is it ok to replace it or a techinical dude is required?
Order a new bios chip
Posted on Jun 17, 2007
    President:
  • 2,961 Answers
The first thing to try, is to look on the motherboard for the CLRCMOS2 terminal pins, this allows you to clear the data in CMOS. The data in CMOS includes system setup information such as system password, date, time, and system setup parameters. To clear and reset the system parameters to default setup, please turn off the computer and unplug the power cord from the power supply. After waiting for 15 seconds, use a jumper cap to short the Clear CMOS jumper for 5 seconds. After shorting the Clear CMOS jumper, remove the jumper cap. If you have changed the ram make sure it's compatable, but if the above has
Posted on Jun 12, 2007
  • andrew pester
    andrew pester Jun 12, 2007
    sorry, continued........ but if non of the above has changed anything, i suspect that the bios chip is faulty, especially if you cannot get into the bios at start up, and unless you are someone brave enough to replace the cmos chip, i'm afraid a new motherboard is required, but if you are getting the bios post screen but then nothing else, i would say the processor is at fault
Computer starts but no diplay shuts down immediate,
Is the power LED on the monitor ON, if not check the power cable connection at the monitor and at the mains.
Check the video cable connection at the PC.
Try a different working monitor on your PC and see if the monitor works on a different PC (the monitor maybe faulty).
Nov 17, 2012 | E-Machines T Computers & Internet
I've got a Philips 221V mnitor and it diplays:
boot your pc , keep on pressing f8 key then select safe mode option, remove the graphic driver, then shut it down, then again start install the graphic driver
Jul 28, 2011 | Philips C.927126 Monitor
I have a HP Pavilion a6430f PC and I'm trying to add a second monitor. After a software update my computer will not recognize the second monitor. Do I need to purchase an upgrade to my current NVIDIA...
go to control Panel and look in the Display settings, you should be able to see your video card in number one monitor as well as in number 2. I hope this helped. Good luck and have a pleasant day!!!
Jun 19, 2011 | HP Pavilion A6430F Desktop PC
D845GEBV2 cannot get any diplay
Hi. You should obviously check if your monitor is working properly first. Just connect it to another PC to try it. If you can hear fans going and computer starting but nothing on display try an old trick- take the power cord out from the back of PC and press power button, keep it pressed for good 30 sec then put it back in and try to start as normal. If that don't work you may find that chip responsible for display (GPU- Graphics Processing Unit) went dead which isn't a good thing. To get passed it you could buy a separate Graphics Card and place it in one of the slots in motherboard. Make sure you know which kind of card you need you would find this info on manufactures website or in your service manual. If you already have a graphics card in it and that don't give you no display try resitting it or replacing if it don't work. I hope you find this helpful. Please let me know if this was any help. Thanks and good luck.
Apr 23, 2010 | Intel D845GEBV2 Motherboard
New hp computer not communicating with Insignia LCD TV monitor
before starting keep press f8. then choose safe mode then if you are in ur desktop try to ressetting your display 800x600 then finally done......
Feb 13, 2010 | Computers & Internet
Hello. This computer will recognize a good
This is the problem with the display capacitor on your motherboard. Try replacing the display capacitor by good technician. If it doesnt solve your problem you need to change the motherboard. But mostly this will solve your problem.
Oct 15, 2009 | HP (D9820-60007) Motherboard
Gateway 2" monitor won't display
blown capacitors this can be fixed I can help or advise you how to do it but it will require soldering internal components.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
Half Display
That Seems to be a panel problem.Benq provides 3 year warranty,Try contacting local BenQ service centre in your country.
Samir
Aug 11, 2008 | BenQ FP71E 17" LCD Monitor
What should i do to my monitor?
I already answer this in other post, but ill try too help..I got the same problem, and th only way i make it work is too remove the power cable and plug it back on..it works..at least for me..but today im taking it to the assistance..
regards
May 03, 2008 | ASUS VW192S Monitor
Asrock K8Upgrade-VM800 Motherboard Logo
225 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
