Question about Citizen Eco-Drive BL006056H Wrist Watch
Watch has stopped and jumped to 12 oclock - Citizen Eco-Drive BL006056H Wrist Watch
  • 2,334 Answers
All you have to do is to reset your watch. If you lost instructions, visit this site:
http://www.citizenwatch.com/CUK/English/settings.asp
Enter the numbers or caliber and find instructions how to reset your watch.
Don't forget to rate, please.
Posted on Jan 14, 2009
I have the Nautica A40008 watch and I can not reset the big second hand to 12 oclock. It stops always at 11
pull the crown out to second position then press start till it gets to 12 then push crown back in
Apr 09, 2013 | Watches
My Casio watch band has split apart where the rubber part holds the main pin to the steel watch band making the band unable to be repaired. I would like to find a replacement watch band.Can you help me?
are you referring to casio mtg900 if so do you mean the rubber part below the G button . If so I do believe casio sells that first link . You can call them if you would like to order it if they still have in stock or for a whole new band
you can see the parts store here
http://www.pacparts.com/model.cfm?CFID=3663724&CFTOKEN=19469938&mfg=CASIO&model_id=MTG900DA-9V&row_start=1&src_model_id=mtg-900&action=list_part
I believe the 12 h and 6 h are the parts you are looking for I am not sure what side you need 12 oclock or 6 oclock , but give them a call they should be able to help you out
the other company that handles watch parts is here
http://www.americanperfit.com/parts/parts.htm
Oct 26, 2010 | Casio G-Shock MTG900DA-8V Wrist Watch
Just bought this watch today (movado 800 series) and the second hand (hand C) doesnt move at all. It is part of the chronograph function. It is stuck at the 9 oclock position. When chronograph is...
I wouldnt try to return it. I would go back and inform the store of the problem you have and they have no choice but to either fix it, show you how to solve the problem, exchange it, or at the least, return it but please give them a chance to fix the issue.
Best wishes,
Aug 16, 2010 | Movado® Series 800 Blue Chronograph Watch...
The 24 hour hand sticks at the 12 oclock posiion on my omega seamaster gmt every 24 hours the hour hand will not pass this position.
It sounds as though the 24hr hand is being obstructed, and that is also stopping the 12hr hand. Try to examine the face carefully for foreign objects (or bent hands). Unless you're very skilled with watches, I would suggest that you take it for repair. If the hands are sticking, gently pull out the crown ("winder") to stop the watch and prevent further damage.
Jul 19, 2010 | Omega Seamaster 2561.80 Wrist Watch
The reset tachymeter don't stop at 12 oclock
you should pull the big button fully out, then by pushing the tachymeter play/pause you can set the starting point
wish it's helpful for someone :)
Jan 25, 2010 | Casio EF503D-1A Watch for Men
Pulsar chrono model pf 3347
Go here and follow the instructions. The link is a pdf of the manual.
Apr 14, 2009 | Pulsar PF3347 Wrist Watch
New watch has stopped
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead or dying battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement or somehow damaged the movement through usage and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Jan 13, 2009 | Watches
Crane and Viceroy ladies RC watch
Hi, Klik and Crane & Viceroy are excellent and robust watches, but due to the radio control batteries need to be changed more often than ordinary watches. Instructions for resetting the time on a Klik or Crane & Viceroy watch. With the watch face upwards and the buttons on the right assume the buttons to be; top button - "A", middle button "B" For setting the watch to GMT all hands need to point to 12 oclock exactly. To achieve this press Button A until the hands start spinning. Stop the spinning when the time reaches a couple of minutes before 12 oclock by repressing A. Inch the time forward by repressing Button A until all hands are at 12 oclock.(EXACTLY). Press Button B within 10 seconds and the time will advance 1 hour and stop. The radio signal will be picked up automatically and time will set itself in a few minutes. Notes: If you have radio dead spots avoid these when resetting the watch and do it away from magnetic or large metal objects. i.e. trays etc. If you are refitting a new battery and have a battery that isn't quite dead, do the advancement of time with the old battery and fit the new one near to 12 oclock to get the best life out of the new battery. If for any reason you want the watch to be in radio mode but read a time other than GMT ( no adjustment is needed for BST ), then instead of stopping the watch at 12 oclock stop it at the time in relation to 12 oclock. i.e. if you wanted the watch to read 30 minutes fast then stop the watch at 12.30. if you want any other info my email is; Charles@adept.fsbusiness.co.uk
Jul 15, 2008 | Watches
Klik r c watch.
problem solved.
regards.
Matt.
Apr 17, 2008 | Watches
Set date
hello..this is not abig problem..just a sincronization one...ususlly I set the date around the 12 oclock in the night..the 0 hour..its easier...if you dont want to do this...well..then just count the hours ..remember you have the 24 hours /day..and remember the date is changing in the night around 12 oclock..
for instance...lets say..now you want to set the date..you count the hours until tonight at 12...you put it lets say...with 12 hours back..and wait the change in the midnight..
the easier way is to set it at midnight
oh...by the way..I saw watches which change the date around 2 oclock in the night..but this is a very small %...99% are set to do it at 12..
good luck
Feb 03, 2008 | Seiko SNA553 Alarm Chronograph
Citizen Eco-Drive BL006056H Wrist Watch Logo
121 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
