Question about Kenmore 22422 Top Load Washer
My Kenmore washing machine stopped spinning and draining water, but would run if I put it in the wash cycle. It is a stacked model. The dryer works fine. Please help!!! My clothes are sitting in water!
  • Anonymous Jan 14, 2009
    I have identicle problem, Model # 110.92596100 though. Will the person who responded, please explain what does "check the did switch" mean?
  • Anonymous Jan 15, 2009
    My machine will go through the intake of water & wash cycle, but will not go any further. Will not drain the water; do a rinse or spin cycle. The water & soap are just sitting in the machine. Mine is also a stacked set & the dryer works fine.
    New Friend:
  • 88 Answers
Check the did switch
Posted on Jan 14, 2009
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Water will drain durring spin cycle
This is normal on some machines. Run it through a complete cycle it should fill, agitate, drain, some will drain down so low then start spinning as it is draining but should stop draining before it fills or stops. Check if water is coming in at the same time it is draining. If not it may be ok.
Dec 23, 2010 | Kenmore 98702 Stacked Washer/Dryer
My washer will not go to spin cycle,.
Hi my name is joyce,
first lets try to get the water out of washer, put on drain cycle, after it drains water out take clothes out of washer, then lets see if it will run on spin cycle, it may have to many clothes, if this does not help then you have a transmission problem, this will defenently need a technichan to look at it. if you need I can look in you area and see if I can find you some assistance.
Joyce
Feb 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 22422 Top Load Washer Logo
95 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
