Question about Insignia I-LC23Q1 23 in. HD-Ready LCD Television
Insignia IS-TVHD30 The TV has worked perfectly for a year and a half or so, but a thunderstorm passed the other day, and now it does absolutely nothing......NO lights, NO responses to switches or remote. The TV is plugged into a surge protector strip along with a DVD player, Satellite box, and VCR. Those all appear to be working; at least they have their "ready" lights on. I suspected a fuse, and took the case off the TV and found a line fuse, but it checked good with an ohmeter. There are no burnt smells, and no unsightly capacitors or other components inside. "Girociclo" got me the name and phone number of the company and support, but they just said to send them the TV. Can one of you please help me troubleshoot this myself? Thanks
  • 2 more comments
  • MarkDC Dec 10, 2007
    Im having the same problem with my IS-TVHD30 and would love to see anything that I can test as well. I also checked to make sure I have 120v across the fuse and thats about where my limited knowledge ended. Any help would be appreciated.
    Mark
    MDCumming@yahoo.com
  • tomabillsfan
    tomabillsfan Jan 21, 2008
    turned the tv off, it was working great, in the morning tried to turn it on and nothing. no red light checked all the outlets, makes a small clicking noise when i turn it on but nothing else. any help?
  • Anonymous Sep 27, 2008
    My IS-TVHD30 power supply started intermittently giving a high-pitch tone only a few months after purchasing. At the time I didn't know it was the power supply. Eventually the power switch wouldn't turn the set on anymore unless I unplugged it from the wall and plugged it back in. After about 18 months, the set wouldn't come on at all. My attempts to find parts have failed. It doesn't make much sense to spent hundreds to repair this $400 set. I just want to purchase a power supply or find a tech documentation so I can repair this one. I've had other Chinese-made power supplies that burn up capacitors quickly; my guess is that is what is wrong here too. This is annoying given that my last tube television (RCA) worked for 20 years without incident.
  • fujis218 Oct 10, 2008
    Oddly enough, I found an Insignia IS-TVHD30 lying on the side of the road and not knowing it was a cheap HD, picked it up and proceeded to see what had gone wrong with it. When I got it home and plugged it in, it basically did nothing. Upon closer inspection, I could hear it attempting to power up and then failing to over and over again. I took it apart and noticed that one of the capacitors was discolored. When I prodded at it the thing completely fell apart. Once I removed the shorted cap, I plugged the thing back in and the power came back on. The silk-screened identifier for the cap was C359 but since it had basically crumbled to bits, I was unable to determine the size to replace it with.
    Figuring this thing might be worth fixing at that point I prodded around the message boards to see if anyone else was having the same problem. Turns out it's quite common but no one has posted a fix for it. So I ordered the service manual and once it came began searching for the replacement part's specifications. Turns out there are 2 C359 capacitors listed in the manual and the descriptions read something like DE0707B221K2K. Not wanting to order factory replacement parts I searched the schematic and found the value listed as 300pf at 1kV. So I went to the local electronics supply house and picked one up for the huge cost of 20 cents American. Once I replaced the part the unit started working well enough without any further repairs.
    New Friend:
  • 129 Answers
Thre are no to many parts that you can test on the board ,I'll send pictures of what and how you can test some components I'l let you know wednesday . thank you
Posted on Jun 12, 2007
Hdmi port not working on plasma tv
Contact the authorized service center to rectify this fault. In most cases, the main board might need replacement.
Jul 23, 2013 | Insignia 42" LCD Flat-Panel HDTV
I have sound and picture distortion (like what happens during a thunderstorm) in my 42 inch insignia lcd tv but not during storms. started about two weeks ago, happens intermittently. driving me nuts. is...
Your probably having what cable guys call a SNR ( signal to noise ) issue. There's no way to know unless you call your cable provider. The SNR should be 32 and above with zero pre/post errors. In case you want to ask the tech what they are.
May 18, 2011 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Insignia tv-30 inch ---model is-tvhd30 has burned capacitor-c359--need to know the value in mfd's.
If it is in the power supply better check the rest of them. most should all be the same value so you may be able to get the value for the burnt one from that. good luck
Apr 24, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Service manual
You can search this database for the service info you seek about your tv here:
http://www.samswebsite.com/photofacts.html
Most service manuals with schematics cost about $27.95 for the PDF version of it, otherwise the paper version is about $15.00 more for handling and shipping.
You will need the chassis number of the unit in question in order to search for it. I hope this helps!
Good Luck!
Rich Lilja
Oct 28, 2008 | Insignia IS-LCDTV32 32 in. Television
Insigna TV
HI
I have a Insigna IS- TVHD30. It come on and have a perfect sound but I can't get a picture. Its about three years old. I went to sleep watching Tv. and when I woke up the t.V. was on, but wasn't showing a picture anymore. I decided to throw it away last week, and plugged it up and it came right for 2 days, it was perfect. Now it has went out a again. Can some help!!!
Aug 24, 2008 | Insignia IS-LCDTV32 32 in. Television
30inch insignia
Sounds like power supply problem (either poor connections or bad capacitors).sometimes they look deformed or you have to check them with an incircuit capacitor tester.
Jul 19, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
No picture
Try a "hard restart". which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent.
You can also visit the manufacturer's website or call their tollfree number for problem solving info.
Hope these suggestions help you out.
Jun 30, 2008 | Insignia NS-30HTV 30" TV
Insignia HD30 TV
Take a look at D517 in the power supply for faulty solder joints. That's a common component problem in these units. Otherwise, if enough transient voltage got by to do any harm you might want to test the following: V504 = 2sa1668 R523 = 56 Ohm 1w N502 = Tlp421 optocoupler IC D509 = 1n4148 If any of this has you scratching your head it's probably shop time... Hope this helps, let me know... Bill
Jun 19, 2007 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Insignia TVHD30
I, need the exact model no. to see if you can get part for it . need also to know if it uses an external power adapter thanks
Jun 10, 2007 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Insignia I-LC23Q1 23 in. HD-Ready LCD Television Logo
570 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
