Question about Brother IntelliFax-2820 Laser Fax
When sending fax, the pages feed crooked
Whenever I send a fax, the pages will not feed in straight they
always go in crooked so the receiver only gets half of the fax
  • 320 Answers
Posted on Jan 15, 2009
I have an HP L7780. We are having an issue receiving faxing. The pages are often only 1/4 complete. There is no reported error. It doesn't happen all the time.
Send a fax on this number
1-888 HP FAX ME (1-888-473-2963)
and see whether you receive a fax from hp or not whenever HP receives a fax from any number it sends back a fax to prove the functionality you can say.
the reason behind reviving the 1/4th fax can be fault at sender's end
Apr 21, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Can not send fax. The receving fax rings but my machine does not respond and send the fax. I can receive ok.
The document does not feed into the machine.
Be sure the document is not wrinkled, and you are putting it in correctly. Check that the document is the right size and not too thick or too thin. (See document types and sizes on page 43).
You cannot receive faxes automatically. Check if "TEL" appears on the right side of the display. In TEL mode, you
cannot receive a fax automatically. Be sure the handset is seated on the cradle properly.
The machine cannot receive faxes manually. Do not hang up the handset before pressing Start/Enter to receive a
The machine does not send anything. Check that the document is loaded face down. Send should show up
in the display after it dials. Check if the machine to which you are sending can receive your fax.
Dec 22, 2010 | HP 1010 Plain Paper Thermal Fax
Not pausing to acknowledge
Open up the feeder to see if a piece of paper is holding a switch actuator down.
Feb 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Having trouble sending a fax and receiving one,, also where does
To send a FAX load the pages in the auto feed tray on the top of the unit. To receive a FAX, load the paper in the paper feeder vertically on the back of the unit. Suggest you consult your users manual.
Jan 19, 2009 | Epson Stylus CX9400 Photo Printer
Whenever I send a fax on my brother intellifax 2820 it feeds crooked, I can not get it to go in straight. Therefore, the receiver only gets half the fax.
what you will need to do is go to a hardware store and purchase some isoprophyl alcahol. put some on a rag and clean the paper feed rollers if that fails there must be some in side that area like a peice of paper, try cutting a file folder to 8x11 in manually force feed thru a the paper feed section. good luck brother tech
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Paper jamming in fax
look for a piece of paper in the paper path. clean all paper feed rollers
Jun 11, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Faxing problems
if you put the document in right direction(face up or face down)-your scanner unit may be out of order or unpluged firmly into the main board socket check it and reinsert scanner unit plug again.
Jan 10, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
198 people viewed this question
James Cagle
James Cagle
Jim Keysor
