Question about Bosch HBL 442 / HBL 446 Electric Single Oven
Bosch hba34b520 I had my electric double oven disconnected and found that it was connected to a 13 amp 2.5mm cable. I was told that I could only have a single oven installed on that wiring. Would I be able to have an electrician connect a bosch hba34b520 single oven to this power supply please as i have been without an oven since December 16th and I have two children one of whom is disabled.
  • Bosch Master
  • 3,463 Answers
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Posted on Jan 14, 2009
I need to download a manual for this product. Where can i find it?
I found a users manual for Bosch wall ovens at Retrevo.com
http://www.retrevo.com/s/Bosch-HBL755AUC-Ovens-review-manual/id/925ci470/t/1-2/
Feb 12, 2011 | Bosch HBL 755 Stainless Steel Electric...
I am trying to find the KW rating of the HBL3550UC so that I can rough in the electric. They couldn't even tell me that info at the store. Thank you.
hi could not find kw rating but found it needs 30- 40 amp supply. it will tell you the kw on therating plate located around the door area.
Jul 23, 2010 | Bosch 300 Series HBL3550UC 30" Double...
Just had delivered Boch HBM13B221B Double oven. There is no cable. How do I attach it to the electrics in the house
Hi.
You need to wire it up with 6mm twin and earth cable.
You must connect it to a seperate 30amp double pole cooker box, and nothing else.
Do not onder any circumstances connect it to a 13 amp socket outlet,
Unless you have a good knowledge of electrics, then I would recommend you get a qualified electrician to wire it in for you.
Please rate my solution.
Thankyou.
Jan 14, 2010 | Bosch HBL 442 / HBL 446 Electric Single...
Does a moffat oven need a 30amp cooker socket or is it ok on a 13amp plug
Unless your talking about one of those tiny, table top ovens, dont use a 13 amp socket / connection.
An electric oven must be connected via a 30 amp SUPPLY - the socket is just the connector at the end of the cable that runs from the fuse / breaker board. A 30 amp supply will use a much thicker cable capable of handing the higher currents.
Whilst a very basic oven may draw less than 13 amps current when operating in some modes, most will draw well in excess of this depending on what facilities they have, e.g. bake and grill at the same time, or maybe a combi-oven - one that can bake and microwave at the same time.
Oct 03, 2009 | Ovens
Bosch double oven, the bottom door won't close all the way
This requires door hinges to be replaced,relatively simple job & parts cheap.Best buy parts from Bosch direct .
Mar 15, 2009 | Bosch HBL 5056 Electric Double Oven
What connection do you require for eye level electric double oven
You need a 45amp circuit for this double oven, under no circumstances , try to run it off a 13 amp circuit.
Thankyou.
Jan 25, 2009 | Neff U1421 Double circotherm Electric Oven
Timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Apr 29, 2008 | Bosch HBL 5056 Electric Double Oven
Bosch HBL 442 / HBL 446 Electric Single Oven Logo
681 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
