Question about LG VOYAGER VX10000 Cellular Phone
Blue tooth voice commands
I have a voyayer phone and a motorola bluetooth but cannot get the phone to understand the voice commands. I have trained the phone but if I tell it to call someone it my respond current time is, etc.
  • 26 Answers
I had the same problem with a Motorola bluetooth. I had to return it to the store because it was defective. It wasn't a problem with the phone it was the bluetooth.
Posted on May 18, 2009
Device can't understand voice commands.Keeps asking for commands and tries to call wrong contacts.
press and hold power and volume buttons to reset the device,pair it with the radio or phone and start over,when doing anything with voice you need to get rid of ALL background noises,including radio and air,(windows down),
Jun 13, 2015 | Motorola Mobility Motorokr T505 Bluetooth...
How do I get my lg ally to respond to a voice dialer call command from my Jawbone bluetooth?
Hi bredebar you need to go to settings. Next you need to hit the wirless &network go to the bluetooth settings and make sure that the blue tooth is connect to the phone and audio. If your having a problem with the voice command it is because your ally doesn't have froyo on the ally. You need that to get the voice commands to work. you can go to the open market and put in voice commands for droids. Hope this helps foryo is frozen yogurt great name. There is another new program coming out be on the lookout for it .
Jan 03, 2011 | LG Ally Cell Phone
Loud Noise
IT will give the noise because of the following reasons
  • Due to signal distortion and also that you mieght be useing faulty bluethooth head set .
  • It also occur due to low bettry chargeing
Things to do !
  1. check your blue tooth head set with other Motorola cells
  2. replace your blue tooth head set
  3. clean the connector of the blue tooth cable
Please Rate !
Sep 05, 2009 | Motorola Mobility Motopure H12 Bluetooth...
2009 Highlander Limited bluetooth phone voice recognition problem
I would try using another phone to see if it works any better cause some bluetooth phones aren't fast enough or have the wrong version. Otherwise you need to replace your Navigation receiver assembly.
Jul 04, 2009 | 2009 Toyota Highlander
VOICE DIALING
You need to Add Voice to Contact first
for that find out the key which is works for Voice Commands.
By default if you hold Volume Up key or 1 or * keys any of these keys may work for Voice Commands.
Sort out then you will get an option enter voice command ..
let me know the result..
Regards,
Suraj.
Feb 19, 2009 | Motorola Mobility RAZR V3
Jabra vbt185z difficulties using voice commands
go to your phone tools and find voice command blue tooth and follow prompts . its all in the phone . the tooth is run by the phone. your blue tooth is only a reciever, the phone is the boss. good luck
Jan 15, 2009 | Jabra BT350 Bluetooth Headset Headset
HF850 pairs with my Ericsson TM506 phone, but can't voice dial
The TM506 (also known as Bella) must support the Bluetooth Handsfree 0.96 profiling.
The HF850 supports Bluetooth Headshet v1.1, v1.2 and Handsfree 0.96 protocol.
Unless you can find otherwise, the TM506 doesn't support Bluetooth 0.96 Profiles. It is my understanding that on the TM506 you must program your voice commands and I understand that to be different.
Nonetheless, the TM506 works very well and seamlessly (other than voice dialing) with the HF850.
Dec 24, 2008 | Motorola Mobility Bluetooth??¢ HF850 Car...
HOW DO I MAKE A CALL USING THE VOICE COMMAND ON MY PHONE USING MY BLUE TOOTH
When the earpiece is in your ear the outside (blue part) is actually the multifuction key. Just press the button and say the command to make a call, and push the button again to hang up a call, it took me a day or two to figure that out too.
Hope this helps
Jul 06, 2008 | LG HBM 730 Bluetooth Headset Wireless...
H700 won't play music thru bluetooth
Pushing in the button (I don't know what you mean by "the middle button" when there is only one button on the H700) it starts the voice dial feature. It will listen for a second and then tell you with a beep that it did not recognize the name. That is your cue to try again. When it does not recognize it again in a couple of seconds ti shut off. The H700 was not designed to use to listen to music on your phone with. If you want to do that you need to purchase something like the Motorokr Blue Tooth unit.
May 19, 2008 | Motorola Mobility H700 Wireless Headset
Blue tooth
Most phones that support bluetooth have a "headset" or "hands-free" profile that the device must be in for the bluetooth headset to work. Can you confirm that your device is in this profile?
Jun 06, 2007 | Motorola Mobility PC850 Wireless Bluetooth...
LG VOYAGER VX10000 Cellular Phone Logo
89 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
