Indesit wixe127 error code F05
Thought it was pump blocked because i found 2x hairgrips in the sump.
  • Washing Mach... Master
  • 3,463 Answers
F05 means that the pressure switch is jammed on full, this is the switch that controls the water level.
It could be a faulty switch, a blocked hose to the switch, or a pump blockage.
Check pump first to see if it is draining o/k.
If o/k ,then there is not a lot more that you can do, unless you are conversant with washers and know how to check pressure switch and pressure chamber and hose for blckage or malfunction.
I would suggest that you call some one in if you can not sort it yourself.
Plz rate my solution.
Thanks.
Posted on Jan 14, 2009
  • florin Jun 08, 2013
    You are the best. Realy, your solution was great, I savee 100$ using your knowledges. Thanks a lot
    Problem Solver:
  • 14 Answers
I removed the drain pipe and ran the wash cycle into two buckets which completed correctly.
I therefore checked the drain connection to the sink and found a lot of fluff blocking up the hole.
The fixya guru suggested it could be pump and / or pressure switch but it was much simpler than that.
Us engineers often dive in at the deep end with technical fixes but sometimes the solution is simple.
Posted on Jan 17, 2009
Error code f-05 on idesit wixe127
F05: Pump Blocked or pressure switch empty not reached
- Check efficiency of J9 connector on card, verifying a voltage of 220V between pins 8 and 9
- Check that pump if being fed
- Check Pump Filter + wall drain
- Change Pump
- Replace Card
Dado
Feb 28, 2015 | Indesit Washing Machines
What does f05 mean on a hotpoint washing machine
f-05 usually relates to either the pump being blocked or the sump of this particular model being full of coins, color catchers etc.
first keep it simple, ensure outlet hose is not blocked or kinked....but if not follow these steps
  • To sort this isolate from mains
  • take off back inspection panel.
  • tilt machine forward- get sum1 to hold it for u.
  • The sump is the black hose attached to drum.
  • place a basin under this and loosen jublie clamp using star head screw driver/ 8mm socket,
  • pull sump downwards and remove any blockage.
  • note the plastic ball is part of the sump assembley.
  • refitt the sump again and tighten clamp, pull down firmly on sump to ensure fitted correctly
if there was nothing in the sump it is sumthing jamming the pump, hairgrip, nail, etc.
tilt machine forward as above with a basin ensuring isolated from mains power
  • pump is attached to other end of sump hose, right side of machine as you look in the back.
  • using flat screwdriver lift plastic tag up and slide pump assembley to the left releasing it from base of machine
  • clip of plastic cover from top of pump
  • remove wires from pump
  • u should now be able to turn pump around so u can see 3 hex head screws
  • remove screws taking note of the position of pump
  • remove pump and clear blockage
  • reverse steps to reassemble
if this does not sort it poss a new pump needed
May 20, 2012 | Hotpoint Washing Machines
I have error f05 come up and now a drum full of water - how do I drain this and get the door open to empty and clean the filter? Believe it could be jammed pressure switch or blockage so need to know...
if this does not sort it poss a new pump needed.
Apr 03, 2011 | Washing Machines
Grey hotpoint washing machine wt741g i would like to know what f05 means water still in drum only a little bit of water but when it gets to the last 30 minutes it starts flashing f05 and wont turn off
from,
hotpoint ace
Sep 10, 2010 | Washing Machines
F05 keeps coming up on my ultima 860 hotpoint 1600 spin w/m,we cant find manual,what is problem?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Fo5 is a pressure switch fault; areas to check are pressure chamber for blockage, pressure pipe sump and pump. Click on a link for more Hotpoint, Creda and Indesit error code definitions or Hotpoint WMA / WM workshop manuals
Mar 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
Indesit wixe127 f-08 error
I have the same problem. Check this info (the below link) I found on F - 08 error for someones hotpoint washing machine. It may be the same thing. There could be standard error codes for all washing machines, maybe.
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&printertopic=1&t=37910&start=0&postdays=0&postorder=asc&vote=viewresult&popup=1
Feb 07, 2010 | Indesit W 123 Front Load Washer
Error code fo5
f05 is normally a fault cause by the pressure switch - often caused by a blockage in the exit hose of the washer. if the water cannot leave the washer in time the f05 will come up because the pressure switch has not told the machine it empty. on hotpoints there is a filter inside the exit pipe from the drum to the pump which gets blocked up. need to remove and clear out the sump assembly and this normally fixes the f05 error. if this does not cure the issue then the pressure switch is probably faulty but its notmally just a blocked pipe.
Sep 13, 2009 | Hotpoint Washing Machines
Hello, i have an Indesit WIXE127 showing error code FO7. Any help/advice appreciated.
F05 is where the pressure switch has not reset within 10 minutes of emptying on any part of the cycle. Basically this means the pump is not pumping the water out. This could be a blocked filter (located on front of machine at bottom behind the kickstrip). Be careful when removing the filter as it unscrews anticlockwise and if the is water in the drum then tilt the appliance back at 45 degrees and put a large bowl underneath to catch the water. If the filter does not unscrew then theres definitley something in the filter. When the filter is out put your finger inside to rotate the impellor. This should spin freely. If this does not solve your problem check for blockages where the grey drain hose connects to the sink (it could be blocked there).
Apr 17, 2009 | Washing Machines
Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Nov 18, 2008 | Washing Machines
Washing Machines Logo
4,102 people viewed this question
Top Washing Machines Experts
