Question about Lands Phones
No service i changed out a phone wall plate, rewired it correctly and now have no phone service
What color wires were there ???
What kind of jack, a new one that had...
white blue/blue
white orange/orange
white green/ green
white brown/brown
If so, the white/white blue would go to the same wires.
If you had red/green and black/yellow, the red/green should go to the white blue/blue.
Posted on Jan 13, 2009
PLUG LEFT IN WHEN PULLING AWAY FROM WALL. NEED DIAGRAM TO REWIRE PLEASE
Most have a tech sheet located behind kick plate sometimes taped to bottom behind plate but you can go to sears parts.com and view wiring diagram
Mar 25, 2016 | Refrigerators
RCA visys dect 6.0 Line 2's light is lit and no dial tone. All handset are in off mode. Only Line 1 is available
Are the phone cables correctly connected to the base unit? Try a new cable for Line 2, if you have separate L1 and L2 jacks. (If the lines are integrated in one jack, make sure to use a 4-conductor RJ11 cord.) I assume the service hasn't been cancelled for line 2 and that you are at a wall plate with both lines.
If you have separate jacks, I like to use a different phone to check the jack. (A simple old fashioned corded, single-line phone is useful to check for a dial tone.) Try checking Line 2 at another jack, if you have one.
If you do not have a dial tone, find where your service comes in. Open the box and look at the terminals. If you are lucky, you have an RJ11 port. Plug in your test phone in to the Line 2 connection and listen for a dial tone. If there is no dial tone, contact your telephone company. They will fix an outside line problem for free. (Mice and other things can damage the wiring. A lightning strike could damage a filter if you use the line for a high-speed internet connection.) If the terminal doesn't have an RJ-11 plug option, you will need to ask your telephone company to test the line.
If you recently had work done on the phone line, check for any wires that are loose. When we got our phone line upgraded to fiber optics, one of the telephone jack lines didn't get connected to the terminal in the new box. We found the wire behind the vinyl siding and got signal as soon as the wire was reconnected.)
If you have a dial tone at the box and no wires are obviously disconnected, you'll need to trace the wires inside to find a broken connection. If one jack worked for Line 2 and another didn't, check inside the wall plate. There are two wall-plate styles. The ones with a keystone jack needs the conductor wires pushed down into the correct slots. A punch-down tool is available from most hardware stores in the wiring section. The screw terminal type requires the individual wires to be stripped and then secured. The correct terminal positions are shown here: http://www.lanshack.com/wire_phone_jack.aspx . Otherwise, you need to trace the wires in the walls to find the break in the continuity. Your phone company will do this for you for a fee. If you have a line filter inside, try replacing it.
I hope this helps.
(I've called the phone company several times when we lost one line. Mice and lightning damage to the filter have both been culprits.)
Jul 08, 2013 | Lands Phones
Hi. I have a new 4-line phone (RCA 25414-RE3) and it is connected like the manual says. But it is not separating line 1 from line2 or line3 from line 4. They are both on lines 1 and 3.... can you help
There are a couple of problems you may have.
First, the wall jack may not be wired correctly or the wire you ar eusing is a single line wire.
The easiest to check is the wire, look at the plug and see if it has 4 copper leads. If it only has two in the middle two slots then it will only connect line 1. If it has 4 copper leads then it should pass both lines 1 and 2 (or three and four). The middle leads are line 1 and the outer two are line 2.
If the wires all check out then you may have a wall plate that is not wired for multiple lines on the single wire. That will require a technician coming out and rewiring the plate. There are also adaptors available at Radio Shack that will combine two lines to one wire if you have both lines on the wall plate.
I have a blog on 4 line phones if you would like other tips about them. Go to the tag cloud and you will see 4 line phone.
Dec 03, 2011 | RCA 25414RE3 Corded Phone
Why does my Breeze randomly change fan speeds and purification levels?
The most common reason for surging or changing power levels is a loose connection somewhere.
1) Make sure the plug in the back is inserted firmly and the wall socket is live. The wall socket should not be powering a high-use appliance such as a furnace or refrigerator.
2) Check to make sure the back screen is inserted firmly, depressing the interior safety switch. (It will click when positioned correctly).
3) Make sure the plate is inserted firmly and correctly in the top and bottom "tracks" inside the machine. The metal contact fingers should be pressing firmly and evenly on both sides of the plate, in the metal screen area. You can bend them a little to increase the pressure. You may need to adjust the upright white ceramic posts to align the contact points. (Sometimes they twist.) Make sure the screws that hold the contact points are in firmly.
If none of these troubleshooting suggestions solves the problem, it may be malfunctioning because of computer issues. Unfortunately, Vollara (new name for EcoQuest) no longer services nor sells the Breeze model. However, customer service will inform you of your options. 800-989-2299.
You may also attempt to locate dealers who still have the Breeze in stock, and/or parts. You would need to do this by first asking Customer Service to locate a dealer in your area. They'll give the dealer your number, hopefully the dealer will call, and you can ask them to inquire among their associates.
Jan 13, 2011 | Ecoquest Breeze AT Living Air Purifier
My GE smart digital timer keeps flashing I need help to rewire this
You posted under GE timer.
Open following link to identify timer and see manual and written wiring instructions:
Most in-wall timers are wired the same way except timers listed on page that work for 3-way switching.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 20, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I HAVE LOST THE INSTRUCTIONS TO MY COMMTEL MOD X1 EXTENSION SOCKET AND NEED TO KNOW WHICH COLOUR WIRE GOES WHERE ??? PLEASE HELP
I lost mine too, saw this post, and then they turned up, so here you are:
COMMTEL
Surface Mounted 2/6a Slave Wall Plate - with ADSL Filter
Instructions
  • Remove wall plate back box by removing the two screws on the front face
  • Fix wall plate to skirting board or wall with screws supplied, allowing adequate space for cable entry
  • Insert exisiting telephone wires into screw connections on the ADSL face plate, following cable colour coding according to the list below, and ensure screws are correctly tightened
  • Screw wall plate onto the back box with the screws supplied, ensuring screws are sufficiently tightened
Cable Colour Coding
1. Not Used
2. Blue with white banding
3. Orange with white banding
4. White with orange banding
5. White with blue banding
6. Not Used
Information
  • No need for external filter
  • Surface fitting, replaces existing wallplate
  • Quick set-up
  • With back box
* If more than one phone or fax IS required to run off the same line, simply add more filters where required. Each individual piece of equipment will require a seperate ADSL filter
* Multiple telephone connections, long runs of cable (over 20m) or low quality telephone cable can adverely effect the performance of your connection speed
Safety Information
Before carrying out any electrical work, always switch off at the mains. If in doubt consult a qualified electrician.
Item Code: 41603016
Distributed by Commtel UK Ltd
www.commteluk.com
It might be worth mentioning that this filter swaps the polarity of the telephone wires: I don't know why. I rewired mine to use it as a master socket, and I have connected the other extensions to the filtered output. This can improve broadband speeds: see
http://www.rob-r.co.uk/other/UKphonecatwiring.htm
Oct 23, 2010 | Computers & Internet
How do I remove the wires from an existing wall phone jack and then rewire to a new jack
pop the front cover off write down witch color wire goes to witch letter on the plastic change to same, most phones line need two wires green and red, but 4 are hooked up black and yellow, for a second line, hook them all up just in case the other wires had a problem and the phone company switced to the other two
Sep 09, 2009 | Lands Phones
HOW DO I CORRECTLY WIRE THIS WALLPLATE TO MY CAT5e CABLE AND PHONE LINE. WHAT COLOR BELONGS TO WHAT?
http://www.ertyu.org/steven_nikkel/ethernetcables.html
this link covers proper pinout for cat 5 cabling. (RJ45). A phone line is RJ11. You can run ethernet cable through a wall and terminate it at a wall plate designed for ethernet (not a standard phone wall plate). You can't use the RJ11 cable currently in the walls for ethernet.
May 02, 2008 | Computers & Internet
No service
have you tried manually setting the network.
menu
settings
network
band - change it from auto to manual
if that does not help then takle the phone and have the antenna on the main-board service or replace
Apr 15, 2008 | Motorola Mobility L6 Cellular Phone
Lands Phones Logo
65 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
