Question about Ricoh Aficio 2015 Copier
Richo 2232c Machine won't power up past the " Please Wait" Replaced the fuser unit last week, Cleared the codes, worked fine, this morning can't get it past the Please wait , Turned on off severa times, Don't know hbow to get it past that mode so I can reset.
  • 4 more comments
  • c_teamann Jan 14, 2009
    I cannot get it to go past "Please Wait" during start up.
    No error codes, keyboard does not respond, Hard Ipower ,unpluged, held down keys during start up.
    It turns on, the "Please Wait" appears and that is all.
    I cannot get to the clear mode. no keys respond.
    Charlie (830) 816-2909
  • c_teamann Jan 15, 2009
    No Can't get that far. It won't even let you get past the boot up stage.
    No keys respond.
  • c_teamann Jan 16, 2009
    Fuser is in good. System will not boot.
    NO codes keyboad and no buttons work?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Sometimes the fuser unit might pop out on you. Do you know how to reseat it?
  • Tim Babcock
    Is there any error codes?
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    Is it asking for toner? Or a error code?
  • Ricoh Master
  • 2,794 Answers
Make sure all the covers are closed on the copier. Check for any broken magnets, door switches, or sensors.
If that doesn't work you should contact a Ricoh representative in your area to do further troubleshooting tests on your equipment.
Posted on Jan 16, 2009
Gestetner Dsc445 service code error
have you checked/replaced the thermostats?
this may also be a problem with your hvt board or power supply.
Feb 26, 2013 | Gestetner Office Equipment & Supplies
OK, ya'll, a problem I have not seen mentioned. About I year ago I replaced the usual suspect capacitors in my E85H power supply. Presto! All was well. One day last week the power went off. The unit was...
Circuitries exspand an contract all the times.Parts flickers in voltages,current in or sitting there for long time or just apply to it.Or cold solders,bad concuctive paths joints.Hundred of answers,cause to a device to malfuctions.
Aug 11, 2010 | Panasonic DMR-E85H DVD Recorder
I have a Ricoh 2232c copier. The ink is fading. I changed a drum and cleaned the machine. I was having troubles with the waste toner lines being clogged but I cleaned the lines and it seems to be...
drums and dev units are meant to last 80 k so check the age.2 have u cleaned the optics? very very important.3 do auto colour calibration in system menu 123 button.or u should be doing it at least 1ce a week.oil has nothing to do with it.
Apr 19, 2010 | Ricoh Aficio 2232C Color Copier
How to refill oil Fuser at unit at Ricoh Aficio 2232c/2238c
These machines use oil supply units located on top of the fuser unit. They are not refillable order another and replace... continueing to run this machine without fuser oil will cause the fuser to fail and copies to look terrible
Dec 17, 2009 | Ricoh Aficio CL7000 Laser Printer
How do I fix error SC552 on Ricoh 2238C?
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared.
The magic keystrokes, clear the error code:
The Fix
In order to clear error SC542, you must perform procedure 5810.
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared
Oct 04, 2008 | Ricoh Office Equipment & Supplies
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Err0r sc 541
Hi
fuser code your thermistor is bad
good luck
Ricoh Aficio 2015 Copier Logo
286 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
