Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Admiral/Maytag fridge/freezer gc2227cdfb
Does the plumbing for the ice and water have to be plumbed for the fridge to work? The light comes on or did (bulb blown( but not making any noises. I do not have a manual and it was ex display
Many thanks
Feed back on electrics ie neutral has a live feed?
Posted on Nov 09, 2011
    Problem Solver:
  • 11 Answers
No..frig will cool just fine without plumbing done-- but you will have no ice :)
Posted on Aug 20, 2009
  • 103 Answers
No the water does not have to be plumbed in for the frige to cool. replace bulb. if short in the system exists then you will need to replace an interal wiring harness.
Posted on Aug 15, 2009
  • 129 Answers
No the water supply to ice and water does not have to be hooked up for it to work.
Posted on Sep 18, 2009
Admiral gc2227cdfb side by side freezer, when I push the button to dispense ice the flap on the door doesn't open and the ice just clogs in the door behind the flap. Any ideas guys?
Defrost the door. I believe that your flapper is froze shut. If you live in a high humidity area in the summer this will happen.
Jun 27, 2016 | Admiral Refrigerators
Ice from refrigerator taste like ammonia
very rarely does the fridge make the water taste bad, it is usually from the plumbing. First check if the fridge has a water filter and replace it if it's over a year old.
May 01, 2012 | Maytag Refrigerators
Msd2756de--water leaking out of the water supply at bottom of freezer hindge.i think this goes up to ice and water on door.is there an easy way to remove facing if this is the problem .
seal or plumbing has come lose.....not really a easy job....possibly the front of door has to be removed or maybe just face plate of the water disp cane removed to retighten plumbing.
Jul 07, 2010 | Maytag MSD2756G Side by Side Refrigerator
Hi I have a Maytag fridge freezer GC2227CDFB The fridge compartment has stopped working, the lights still come on when door open, the motor seems to be working, when temp. setting is turned down to 0 the...
Your problems are exactally the same as mine. I have taken the freezer back panels off and fornd the elements blocked with ice, the upper and lower channels to the fridge are blocked with ice and obviously therefore no0 cold air is going the fridge, I have de-frosted the freezer and put back together and everything works great for 2 weeks when the same thing accurs. My settings for both fridge and freezer are on the lowest possible, but the wife does fill the freezer with too much food! I guess I need an expert in!!
Jun 16, 2010 | Admiral 26 cu. ft. Side-By-Side...
Where to get pipe to plumb in fridge freezer need 10 metres
If you mean pipe that connects to the ice maker, you will need to go to a Lowes, Home Depot, hardware store, or plumbing supply and ask for 1/8 in copper pipe or simply "copper tubing for an icemaker"
That size tubing comes in short rolls but you will need enough to make at least one loop so that you can connect your redrigerator and then push it back into place--I would say roughly 8 to 10 feet, depending on how much room you have. I am assuming that your home is already roughed in for an icemaker where you will be putting your refrigerator. If not you will need to call the plumber.
Mar 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
Plumbing in fridge/freezer
That is the water inlet for the ice maker. It is 1/4 inch diameter and will need to connect to a valve of that size with 1/4 inch plastic or copper tubing.
Please rate if this helps-
Mar 23, 2009 | Whirlpool Home
Not getting ice or water
Shut off the water, disconnect the supply line at the fridge. Look for dirt dibri etc.
Has the water been shut off to the home or up the street recenlty?
This often times loosens sediment and it gets trapped in your plumbing devices.
Dec 04, 2008 | Refrigerators
Water & Ice do not dispense. Maytag ICE2o
Possibly the water valve (also known as a solenoid valve) on the back of of your refeer has gone ka-put. It is easy to find and spot. The water line from your source (out of the wall) goes to this valve. If it is not operating, you will get no water supply thru that line into your dispenser or your ice-maker unit. No water in means no water and no ice out. This is a pretty simple fix you can do yourself. The part is reasonably priced. Get the model number of your refrigerator off the door and contact your local distributor for your brand. Make sure you turn your water off at the wall, or house, before you start taking that plumbing line apart. Otherwise, get yourself a surfboard and lay in a good supply of paper towels. Take your time and unplug your unit from the wall to be on the safe side...
Mar 06, 2008 | Refrigerators
Samsung rs21dcsv refridgerator
THE PROBLEM CANT BE ON THE FRIDGES PIPES.THE PROBLEM MUST BE AT THE FILTER OR ON THE WATERSUPPLY.
Feb 13, 2007 | Samsung RS2630SH Side by Side Refrigerator
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
648 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
