Question about Kenmore 22422 Top Load Washer
Kenmore top loading washer not draining correctly
It appears that the drain is clear, but when the washer drains- there is some water that backs up. I put a hose with a bladder in the drain for 5 minutes, and thought it was clear? I don't know if this is a washing machine problem or a plumbing problem. Thanks
I had a similar problem---repairman took off the drain hose and found a curtain tie back stuck in the hose.(washed it two days before, wondered where it went) We were told that small items often float over the top of the tub and clog up the drain hose--he suggested using a small bag to wash socks, hankies ect. This problem cost us $75 to fix, but we could have done it ourselves. Good Luck Jen
Posted on Jun 13, 2007
Why is it displaying f2 code and will not drain?
The F2 fault code indicates a problem with the washer's drain system, and you must troubleshoot the problem to determine how to fix the washer and clear the code.
Clogged Drain Hose The drain hose on a Kenmore washer should remain free of obstructions so the water drains from the washtub. the drain hose behind the washer can impede the flow of water from the washer. A drain hose inserted more than 4 1/2 inches into a floor or wall standpipe drain system can cause the water to siphon back into the washtub.
Stuck Water-Level Pressure Switch Your Kenmore washer uses a water-level pressure switch in the control panel to detect the level of water inside the washtub. You can find the pressure switch behind the control panel in top-load models or attached to the inside wall of front-load models. The round switch is approximately 3 inches in diameter with a clear or black plastic tube connected to the bottom or side of the switch. The tube runs from the pressure switch to the exterior washtub. As the water fills the washtub, it changes the air pressure inside the tube and lets the switch know when the water has reached a predetermined level. A stuck contact on the pressure switch can stop the advancement of the wash cycle and keep the water from draining. A few taps on the top of the switch with a screwdriver handle can release the contact and fix the problem causing the F2 error code.
Jun 12, 2015 | Washing Machines
What does SD error code mean on Kenmore HE 2 plus front loading automatic washer
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
Leaking water. The hose is draining correctly. Not plugged up
you may either have a leaking drain hose or bad water pump. these washers are famous for drain pumps leaking. this is caused by using to much soap. 2 tablespoons per load.
Jun 03, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore He 3 model 11042832200 water leaking from the dispenser and draining down the outside of the washer. Water drains into washer fine when the dispenser cup is not in place, so there doesn't...
If you take the top off, you can see the whole part called the dispenser, https://www.searspartsdirect.com/model-number/11042832200/0583/0153200.html
Check all the hoses etc. Yes you can even run the machine with the top off and see where the leak is. To take the top off there are three screws in the back at the top and when you remove those, the whole top lifts a slides back and comes off.
Oct 14, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
What does code F mean
F is part of a system fault code. There should be additional characters (numbers) in addition to the F.
Here's what I get from a Cabrio Owner's Manual if there are numbers after the F:
F## code (F-type error code) appears in display
System error code. Press START/PAUSE once to clear the code. Then press START/PAUSE again to restart washer. If code appears again, call for service.
I called Whirlpool at 1-800-442-1111, and according to customer support the manufacturer intentionally no longer provides descriptions for F codes (though there are still a few owners manuals that will describe something like F21 = Long Drain). Check to see if your owner's manual provides any F code help in the troubleshooting section.
Generally, what I was told is that F codes indicate customers need help from a technician. Not always completely true, and really not very helpful--especially if you want to attempt to avoid scheduling service.
Since there are numerous F## codes, please provide the specific code number if you desire further assistance.
Here are letter codes Whirlpool provided in the owners manual (copying from a PDF works poorly):
oL (overloaded)
appears in display
Load too large. If an overload is detected, the washer will drain any water and
detergent in the washer. Remove several items and add HE
detergent. Close lid and press START/PAUSE.
uL (unbalanced load)
appears in display
Load not balanced. The washer is
running a load-balance correction
routine.
Allow the machine to continue. If the dial is flashing and the
machine has stopped, redistribute the load, close the lid, and
press START/PAUSE.
LF (too long to fill)
appears in display
Washer taking too long to fill.
Drain extends more than
4.5" (114 mm) into standpipe.
Check plumbing for correct drain hose installation. Use drain
hose form and attach securely to drainpipe or tub. Do not tape
over drain opening. See "Installation Instructions".
Ld (too long to drain
water ) appears in
display
Washer taking too long to drain
water. Drain extends more than
over drain opening.
Lower drain hose if the end is higher than 96" (2.4 m) above
the floor. Remove any clogs from drain hose. See "Installation
Instructions".
etc...etc...
Jan 11, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
Kenmore 90 series washer model 20922 wont drain
have you tryed blowing back the drain pipe to clear and sourse of fault,also is the water element heater working ok?it could be waiting at a thermostop position till its up to correct temp,hope this helps
May 27, 2009 | Kenmore 15944 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Will not fill with water goes right down the drain,works sometimes
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite - F02 trouble
Hi jbll,
The f02 code is always from a slow drain issue. This washer allows only 8 minutes for all the water to drain and if it is not gone in time you get the F02.
This is the proper check sequence for that problem.
Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects. You can remove this easily and replace it if needed.
If the above does not correct the problem, replace the pump.
I hope this has helped, Lots of luck . Mike Anderson
mca0824@aol.com
May 02, 2008 | Kenmore 4292x Front Load Washer
Kenmore 22422 Top Load Washer Logo
62 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
