Question about Frigidaire FEB24S2AS / FEB24S2AB Electric Single Oven
Frigidaire FEC77B-1 Wall Oven has stopped working
The oven has suddenly stopped working, however the interior light works. I have just reset the clock, but the green indicator light does not come on when I turn the oven on. I have no manual, of course.
Any ideas? Thanks very much
bigg t
  • 640 Answers
SOURCE: Fiigidaire gas oven trips power when I turn oven on
disconnect the wires going to the oven ignitor,turn the unit on see if its trips.if so the ignitor is shorted if not then disconnect the wires that go to the coil of the gas valve and do the same.i think either one of these is your problem.also if theres a fan in the oven do the same.
Posted on Jan 06, 2008
SOURCE: Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Posted on Oct 04, 2008
SOURCE: instruction manual for Westinghouse wall oven
Obtained info from retailer
Posted on Jun 22, 2009
SOURCE: Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Posted on May 31, 2010
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
Posted on Aug 07, 2010
Frigidaire Gallery series model GLEB30T8CBA key pad not working
Hello Dana, thank you for your post!
From my understanding your Frigidaire oven is displaying an error code of "F8" and your keypad is not working properly. An "F8" error stands for runaway temperature (overheating). I would recommend performing a reset on your oven and you can do that by disconnecting the power cord for at least ten minutes.
If that does not help correct your issue then you could have a problem with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Jan 10, 2016 | Frigidaire 30 in. Electric Gallery Series...
Boiler does not work ellameny is good
Good Morning James, thanks for your post!
From my understanding your broiler feature is not working on your Frigidaire wall oven and the element is good. It could be a potential issue with the thermostat or connector of wall oven. If there is a miscommunication within the wall oven you may be able to perform a reset to clear the issues. If you would like to attempt a reset you would need to flip the household circuit breaker off for roughly ten minutes. If that does not correct your issue I would recommend contacting a professional technician for assistance in diagnosing your wall oven. Hope this is helpful. -Matt
Mar 05, 2015 | Frigidaire 30 in. Electric Gallery Series...
Belling evolution 152 main oven stopped working and clock gone out.
Have you checked the power source to the oven? Has the cord come out of the wall plug? Has a circuit breaker tripped? Once the obvious things are checked and proven good will it be necessary to dig into the interior of the appliance.
Oct 14, 2014 | Ovens
Frigidaire Gallery oven won't work after we used the self clean feature. All the controls seem to work & we are not getting an error message, however, when it says that the door is locked it is...
Hello Gillian, thank you for your post!
Let's try reprogramming your wall oven by either unplugging it or flipping the circuit breaker off. It is necessary to wait roughly ten minutes and then turn your wall oven on. Select an option and confirmed that the door is securely latch. If the issue persists, then the temperature may have tripped the internal sensor of your wall oven and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Also, your wall oven may possibly have a communication problem with the EOC (Electronic Oven Control). Personally, I would recommend contacting a professional for a further evaluation.
Best regards, Chris!
Dec 25, 2013 | Frigidaire 30 in. Electric Gallery Series...
My wall oven's heating elements stopped working. Clock, enterior light still work.Model REG74BL*3
Sounds like one leg of the 220v ele. supply has tripped. All thats working, works off of one leg. The elements need both legs to heat. Find your breaker for the oven, reset breaker. It may look ok, but flip the breaker off and then back on. This should fix it.
Please rate solution
Sep 02, 2009 | Frigidaire Ovens
Oven elements suddenly quit
check your power supply for 240volts, at your service panel and have it checked at the range thats the easiest step to start with and if both elements are that way thats what it sounds like now,theres no internal fuse I know about.
Jul 23, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Older Ceramatop GM Frigidaire oven stopped working-stovetop works
If it has a timer of any description, make sure it is set to manual, refer to your instruction book.
Dec 10, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Light won't shut off
Amazing, I had the same problem, was told the same thing, even quoted the same amount!   There must be a playbook with stupid answers by repair people.  Anyhow, here is how I unlocked my oven:  "Press and hold the 'Lock' button for 3 seconds then let go and it should unlock in about a minute."  Hope this works for you. Don
Nov 13, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Open Questions:
See all Frigidaire FEB24S2AS / FEB24S2AB Electric Single Questions
Frigidaire FEB24S2AS / FEB24S2AB Electric Single Oven Logo
484 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
