Question about Makita BO5010 5" Random Orbit Sander
Hi. I like to buy makita orbit sander 5" for my lether clean and conditioning business. this is adjustable speed,,,,which is good but one felt for $35.00??? I think it is soooo much for one pad ( felt) Do you have any idea where i can get chipper makita 5" felt? please help.
    Problem Solver:
  • 15 Answers
Big lots have them for sale, on occasion. I've purchased 5" felt there several times.
Posted on Jan 28, 2009
How do you change speed on mikita BO5030 orbit sander
If there is no adjustment on the trigger or a roller knob its not adjustable.
Aug 14, 2014 | Makita Bo5031k 5" Orbital Sander...
Makita palm sdander BO5012 Manual
Go to the Makita website at
www.makitatools.com/en-us/Modules/Home/Default.aspx.
Use the search box to look up your model number. Your unit is discontinued but if you click on the red model number you'll go to a page where you can view or download the owner's manual and parts breakdown.
Oct 19, 2012 | Makita BO5012K 5" Variable Speed Random...
I'm trying to put the new backing pad on a makita b05001
you should find a felt plug in the center and after removing it you will find a bolt that needs to be removed to install the new pad. You can go to makitausa.com and download the breakdown for this tool. On the right side of the site type in your model number. If I have helped you would you please vote accordingly and thank you
Sep 09, 2011 | Makita 5" Random Orbit Sander
I have been using a Makita random orbit sander model BO5010 for years without problems until I replaced the pad with a Porter Cable 13910, sold as compatible. Now the sander takes off, ie: increases speed...
HI, i have a feeling the pad could be the issue there. The genuine Makita one is designed for the motor, so unless the the replacement is exactly the same thickness, diameter, and weight then you will have problems. Imagine putting a small wheel designed for a car on a truck, that kind of issue. Best thing to do is to try putting the old Makita pad back onto the machine and see if that make any difference. (that is if you still have it) At work we have had similar problems where we have used non-genuine circular saw blades onto our Makita saws, and its has burnt the motor out.
Jan 13, 2011 | Makita BO5010 5" Random Orbit Sander
Hi, my BO5010 spins like a grinder if it is not held tightly to the workpiece, can it be fixed? Thanks, Ope.
Just under the sandpaper pad is a bearing that allows the pad to work as an orbital, that is it can turn freely, independently of the armature. If enough sawdust builds up around or inside this bearing the pad will spin like you describe and this is a fairly common problem with orbital sanders. You need Makita part number 211236-8 or a bearing #6002LL. It's fairly easy to replace; remove the screw in the center of the pad and remove it. Depending on which is tighter, the bearing will either be in the back of the pad or it will stay on the armature. Pry it off/out of the sander. Reassemble everything with the new bearing and you'll be back in business.
Dec 30, 2010 | Makita BO5010 5" Random Orbit Sander
I need a new pad ours is worn out. makita 0125mm B05010 120 volts 532117A 8 wholes.
Buy from one of the many on-line parts sellers. Or do a Google search and you'll find hundreds.
Aug 06, 2010 | Makita BO5010 5" Random Orbit Sander
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
Putting Sanding paper on makita sander
A makita power planer is just what it says, a planer. It has blades that spin at high speed and remove a thin layer of wood with each pass. The orbital sanding sheets go on another tool called an orbital sander. Write back if you find the sander and can not figure out how the sheets go on it.
May 02, 2009 | Makita 9404 4'' x 24'' Belt Sander
Makita random orbit 5". The pad flew apart. Is it replaceable ?
Usually there are 3 screws holding the plate to the eccentric assembly. The pad is formed to a metal plate and is sold as an assembly. You can go to Makitausa.com with the model number and get a replacement pad.
Feb 07, 2009 | Makita 5" Random Orbit Sander
Makita 5010 will not work in random orbital mode
It sounds like the bearing in thee bottom plate is seizing. If you turn the pad by hand does the motor turn. It should be smooth. I would look at that. The bearing number for Makita is 211236-8 or if you can get a generic bearing it is 6002DDW. Let me know
Jan 11, 2009 | Makita Tools & Hardware - Others
Makita BO5010 5" Random Orbit Sander Logo
117 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
