Question about HP DesignJet 750c plus InkJet Printer
HP 755 CM CARTRIDGE MISSING ERROR
Replaced the black cartridge & message said to seat cartridge. Turned the plotter off then back on & got a cartridge missing error during the alignment routine.
  • Anonymous Jan 21, 2009
    I have the exact same problem with the missing cartridge and reseat error.
  • Anonymous Mar 24, 2009
    I have same problem - did you ever fix? if so how?
  • 53 Answers
This normally points to a worn ribbon on the carrage. Make sure the ribbon where the cartrige makes contact is really clean, if cleaning make sure the plotter is turned off. Sometimes a build up of ink can cause problems. The bad news is that if the ribbon on the carrage is worn it firstly comes with the carrage as a unit, and secondally the carrage is no longer available from HP
Posted on Feb 06, 2009
What is the solution to 59.51 error on HP 500 color LaserJet printer.
59 error refers to a Printer motor Error.
59.51 however should not appear on screen.
59.5 is a "Print Cartriddge motor Startup error". The last character should be a letter for which Toner (ie. C, M, Y or K). However I would suggest that the 1 would be the Black motor (seeing as it is the top one). Considering you have replaced the DC controller recently I would say the most likely cause is you have either misconnected or not connected a cable. recheck all your DC controller connections and pay particular attention to connectors J1013 (Cyan Motor), J1031 (Magenta Motor), J1032 (Yellow Motor) and J1033 (Black Motor).
OR
1. Check the cyan cartridge for broken pieces and make sure the drum spins. if so, replace the cyan cartridge
2. Check that connections on the cyan print-cartridge drive motor and on the driver PCA are seated correctly.
3. Replace the cyan print-cartridge drive motor.
4.If error persists, Replace the driver PCA.
5. Replace the main drive assembly.
Dec 06, 2016 | HP DESIGNJET 500 InkJet Plotter Printer
750c plus was turned off and now says printer cartridges missing
Pull out the cartridges, turn the plotter on and install the ink cartridges one at a time - making sure each one is recognized. One of them may have gotten a power surge and had the electronics burned out - - replace that cartridge with a new one.
Mar 28, 2013 | HP DesignJet 750c plus InkJet Printer
I've received the error message: "Printer
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Dec 23, 2010 | HP Photosmart C4580 All-in-One InkJet...
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Film + error lights flash. I have replaced the ink
This indicates that either the black print cartridge is faulty, misplaced or missing. Try inserting a different black cartridge. Also firmly press the large green plunger fully down once, and then release it. The plunger should return to its original position. Then reset the printer and try printing again. If the problem persists try using a new black cartridge and primeit before use with the power on.
Sep 24, 2009 | HP DesignJet 330 InkJet Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
The HP Designjet 1055cm has 4 ink cartridges, 4 printheads and 4 printhead cleaners. My question is: Will the plotter still work properly if I just install the black ink cartridge along with the printhead...
I doubt it. When the printer powers up, it checks to make sure that all modules are in place and functional. If one is missing, you'll get an error message.
Dec 10, 2008 | HP DesignJet 1055cm InkJet Printer
'Cartridges Missing' error. I have just replaced the belt on my 750c plus and reassembled. However when I restarted the plotter, the plotter does not recognise the print cartridges promoting 'Cartridges...
HP 750C Black cartridge quit in the middle of plotting chart. Replaced black cartridge & does not make contact with something. Cleaned contacts, turned off plotter, disconneted cables, reconnected & turned back on. Still says that black cartridge is missing. HELP!
Dec 11, 2007 | HP DesignJet 750c plus InkJet Printer
Error message Alignment
There is no doubt in my mind it Will be the cartridges you are using, alignment will continue to be requested if print out is missing bits do yourself a favour and use HP gen., not trying to plug HP just telling you the facts
Dec 06, 2007 | HP PSC 750 All-In-One InkJet Printer
HP DesignJet 750c plus InkJet Printer Logo
1,155 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
