Question about HP PSC 2110 All-In-One InkJet Printer
HP 2110 ALL IN ONE PRINTER
HOPE YOU CAN HELP!!! When I turn on the printer it goes through the set up sounds, cartridges go back and forth, but then starts to make a different sound and then goes in to sort of sputtering, ttttt, ttttt, ttttt noise. I have tried to take the machine apart and the sound is coming from under the button panel. I can't get to that spot to see what is there. After about a minute it stops, the green lights blink and the machine does nothing. If I press start, it sounds like it wants to copy, but then just says busy. When I lift the top I notice the light on and the part(looks like a bar) in front of the light, moves back (toward the button panel) in spurts too, and thats it. I have tried in the past to just keep shuting and restarting, and once in a while, if I'm lucky, it works, but most of the time it doesn't. The printer is about 4 years old, do I junk it or do you think it can be fixed??? HELP!!!
    Genius:
  • 2,985 Answers
Take a look at www.fixyourownprinter.com for that model But yes time for the next one I guess
Posted on Jun 12, 2007
My printer was in storage for a year, I now have it out and put new cartridges in it and it said it needed to align, so it printed out the aligning paper however it then said scanner failure and the...
Do the following:
a partial reset by pressing and holding Cancel and the Left Arrow while plugging in the power cord.
Wait 30 seconds (which was originally designed by help desks so the clients would calm down).
Hold down cancel and LEFT arrow buttons on HP 2110, while plugging the power to HP 2110.
Release the cancel and LEFT arrow buttons.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 11, 2010 | HP PSC 2110 Color Printer
RE: HP 2110 all-in-one printer. I have put in a new Black HP toner cartridge (color is OK). The printer then goes through the "Align Print Cartridges" process. After the cover page (which prints...
Turn off the printer
Clean the Scanner Glass with Lint Free Cloth ( drop 2-3 drops of water on Cloth, Squeeze it and Wipe the Scanner Glass.
Also try to switch/change the Wallsock/Surge protector socket since the Scanner bulbs are not getting enough power to scan the page
Jun 17, 2010 | HP PSC 2110 All-In-One InkJet Printer
Hp psc 2110
hello, let me start by asking a question giving a few tips. Hopefully things will work out.
First, you said, "you have replaced the cartridge. "
Did you just replace it?
Remove the cartridge and make sure you take off the little sticker tab the covers the print head. I have had many customers over the years that have made this simple mistake.
If this is done. I want you to place the ink cartridge back in properly.
Next power off and unplug your printer.
Wait about 1 minute and plug back in a power back on.
at this point and time it should ask you to do a new new cartridge printer alignment calibration page.
If it does not prompt you to do so please refer to your manual on how to manually do one.
If you do not have your manual let me know. I can do further research and help you with that too.
More that likely this simple procedure will reset your printer and help it recognize there is a new cartridge placed in the machine.
hope my advice helps .. if you appreciate my help lease remember to leave a good rating and a testimonial.
If problem is unsolved please write back for more problem solving.
Mar 28, 2010 | HP PSC 2110 All-In-One InkJet Printer
Installing a new black ink cartridge and i keep
chech the part number of your cartriges, and also the expiration date for both cartridges
Mar 17, 2010 | HP PSC 2110 All-In-One InkJet Printer
HP psc 2110xi all in one printer scanner copier
When I turn on the 2110 printer the scan light just keeps moving forward a small amount and to goes back to the home position. It will do this for about 5 minutes and then shut donw.
Mar 05, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2110 incorrect ink cartridge message.
Hi plabonne,
I hopped out to HP's support site for stats on your cartridge and found some info at this link:
http://www.shopping.hp.com/webapp/shopping/supplies_model.do?product_code=C8648A&jumpid=oc_R1002_USENC-002_HP%20PSC%202110%20All-in-One%20Printer&lang=en&cc=us
are you using an HP 57 Tri-color cartridge? HP printers work best with HP cartridges and often have problems with refilled cartridges. the grinding noise you're hearing makes me wonder if the cartridge isn't seated all the way in its little carridge (the plastic part that holds the cartridge). have you had a chance to slip teh cartridge back out and try gently slipping it back in again?
here's another link to try for info for this model of printer (HP's support site), with specifics about your error message about half way down the page:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu05206&dlc=en&product=79488
hope this helps!
-JW50
Nov 04, 2008 | HP PSC 2355 All-In-One InkJet Printer
Printer not printing
hope you are not properly setup your cartridges
  1. turn off your printer
  2. open your cartridges
  3. setup properly
  4. go to printer properties then if your printer ink show press
  5. test print okkkkk
Mar 05, 2008 | HP DeskJet 930c InkJet Printer
Hp 5550 Deskjet Printer
your printer needs to be reset by printer technician... usually old printer have thier limitations and need to reset. try to visit manufacturers website
Jan 12, 2008 | HP DeskJet 5550 InkJet Printer
Hp 2110 All in One Printer
Does the machine ask you to "align" the print cartridges when you turn the machine back on? If the alignment page when finished printing is missing a key color (say yellow), then the alignment will not succeed.
Jul 29, 2007 | HP PSC 2110 All-In-One InkJet Printer
when ever i get that message it's when i use a "Non-HP" replacement cartridge...try using a HP catridge, or most likely, the printer has reached the end of it's usefull life!
you can try a "full reset" of the printer by..
-unplug it and let sit for a little while,
-BEFORE plugging it back in, press and hold both the enter and cancel buttons,
-plug the power cord in, and wait to release the buttons until the display on the printer tells you to,
-in many cases, this corrects some problems (especially that awfull grinding/ratcheting noise).
after many years of faithful service, i think mine is officially dead though...even the full resxet doesnt help.
Oct 26, 2006 | HP PSC 2110 Color Printer
HP PSC 2110 All-In-One InkJet Printer Logo
151 people viewed this question
Clive
Clive
