SOURCE: 42PF9956/37 SHUTSDOWN...
Ok. I got my tv back on.
I pulled off the back cover and found the relay that was clicking.
I have two blue relays next to each other that click when the power is pushed.
I placed a hair dryer over the relays for about a minute.
Once heated up, it only took 4 tries to get the TV to stay on.
SOURCE: Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
SOURCE: philips 50" plasma ysus board troubles
Check for shorts, blown fuses on ysus, if blown replace entire board, easier than locating many of the parts installed on the board.
SOURCE: TV won't power on, repeating doulbe red light blink
Question
Television is not working, screen is black, blinking red led.
Answer
Television is probably malfunctioning due to electrostatic discharge. Try resetting the television by unplugging it from the power outlet for 10 seconds.
SOURCE: I have a Philips LCD
Service manual says: Error code 14 - audio power amplifier section. The tv switches to protect and blinks one long and four short flashes.
I found a manual and 5 blinks states hardware failure, should i try changing the power supply out?
