Tv keypad on front is locked and can't find remote
While attempting to change the input on the tv I inadvertantly locked the front buttons panel on my Mitsubishi Medallion tv, I also cannot find the remote and was wondering if there is any other way to unlock it?
After reading a similar issue on fixya about another person having a similar problem and holding down the setup button for 10 seconds, I tried it on my television (although I don't have a setup only a menu button) and it worked. Thanks.
Posted on Jan 14, 2009
Changing inputs on hitachi tv 46w500 with out a remote
The Hitachi 46W500 has an Input button on the front of the TV. (This is the second button from the right. The right-most button is the Menu Button.) You should be able to press this repeatedly to switch between inputs.
If the Front Panel Lock is engaged, you need a remote to unlock this. (Only the Power button works when the FPL is engaged.) A universal remote which has a code that matches that needed to get the Menu button to work will do the job.
I hope this helps.
Mar 22, 2013 | Hitachi 46W500 46 in. TV/DVD Combo
MY RCA TTE 20V500T TELEVISION IS STUCK IN CHILD SAFETY AND TURNED OFF W/NO REMOTE TO ACCESS THE MENU
Without remote its not possible to disable child lock. If it possible to arrange the remote then you can do the following to override the lock.
1.Press VOL+ on the remote and CHANNEL + on the
front of the TV at the same time. Enter New Pwd.
will appear on the screen. (You must be in the Enter
password screen when attempting this).
2.Press the number buttons to enter a four-digit code.
The code will appear on the screen as you enter it.
3.Press OK to save the code.
4.Press MENU repeatedly to exit the menu or the menu
will automatically disappear within a few seconds if
no buttons are pressed on the remote control
Dec 10, 2012 | RCA 20V500T 20" TV
How to change input on tv without a remote
Which TV do you have? Some will have an Input or Source button on the front panel. A few will have an option to change the source from the menu. Both of these options require the front panel lock to be inactive.
A few older TVs allowed you to find the A/V input by pressing Channel Down on the front panel buttons until you passed channel 2 (or Channel Up until you nearly reached Channel 2). This option wouldn't work if the A/V inputs had been deleted when someone minimized going through unused channels.
If the Source or Input button was only available on the remote, you will need a universal remote that includes this feature. These cost a bit more than the lowest end remotes. Then you will have to try all of the codes to find the one that makes the Source button work with your TV. (Several codes may work for On/Off but not the change input.) The Universal remotes that can be programmed from a computer (USB connection) will be the easiest to set up. Remotes.com may have a replacement original or substitute remote for your TV that should work for all of the TV functions.
I hope this helps. Please add a comment with the TV make and model for specific options for your particular TV.
(low end TVs usually only had the Source/Input button on the remote.)
May 12, 2012 | Sony Televison & Video
Tv was working, then it went into no signal as I was attempting to work on color contrast
Hi:
You may of went inadvertly selected another video input, try changing sources or look for the input button or source button on your remote..
Aug 03, 2011 | Televison & Video
We have the M220MV. Cannot change channels using the numeric keypad on the remote. I know it should be possible, the manual says you can change channels this way. If not, the last channel button would be...
Hello
Reset your Tv to factory settings. It will unlock all locks including front panel lock.
Reset All Settings
Return all Picture and Audio settings to factory default. A screen will come up to confirm your
selection or to cancel it. Press Left or Right Navigation buttons to make the selection, and then
press OK to accept it.
Setup Wizard
Use this function to return to the Initial Setup menu
Go to its user manual for Initial setup menu details.
OK.
Apr 24, 2011 | Vizio M220MV 22 in. HD-Ready LCD TV
We lost the remote and we are trying to hook up our Wii to the front panel box. How do we change the input to the front panel without the remote
On the side of the TV there are a set of buttons. An Input button is next to the Menu button and will let you access the different sources connected to the TV. For the front panel input, look for the source labeled Front. (There are also volume control and channel +/- buttons.) The button order is Input, Menu, Vol -, Vol +, Ch -, Ch +.
If you want, you can get a substitute remote that is guaranteed to match the original remote's features here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=32V524T&uuid=12935850039140 .
I hope this wants.
Dec 29, 2010 | RCA 32V524T TV
Seems like some type of control board problem. Remote will not work on tv, but works other devices. Manual controls are squirelly. Cannot change inputs. Can move to other inputs on menu but when I hit...
Thats a bad button on the front keypad of the tv . The remote does not work because the tv micro sees a button pressed all the time and never listens to the IR reciever . If you pull the front speaker grill off you will find connector ZF just below the keypad or just inside the access panel. If you do remove that panel don't touch anything else.Just follow the wires down from the keypad to connector ZF. Connector ZF is inline with the wires to the front keypad. Unplug it . Then remote will work like normal. Use it like that or have the front keypad buttons replaced.
Oct 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Cant change channels or input using front panel/no remote
Buy a new remote,tries this website for an exact remote or very closse to the original.1-800-Factory Original.
Sep 30, 2009 | Emerson CR202EM9 TV
Panel Lock on Toshiba LCD 27/30WL46 Sereies -- how to Unlock?
I WOULD LIKE TO KNOW HOW COME EVERY TIME THAT I EXTINGUISH THE TV á. THE ACCENE THE MEMORY HIM AZZERA,SE POSSIBILE TO KNOW ITS MOTIVE
Oct 22, 2008 | Televison & Video
I saw your response to a question about the Toshiba 32A33 TV ...
Definitely, there is some keypad failure. There is a continuous contact anyone of the key. Since key is contiunuosly giving command to the processor Remote function is automatically cutoff. My simle Tips to find out key failure. Good key give "Tick" sound when you press the key softly. The sound is very very low, you have to observe carefully. Otherwise blindly change all the front panel key. Cost is very very low. When the keypad problem is solved, remote will function automatically.
May 19, 2008 | Toshiba 32A33 32" TV
Televison & Video Logo
169 people viewed this question
Top Televison & Video Experts
Electro Med Services...
