I am an avid Keurig user. Recently, I noticed that there were white particles floating throughout the water. I have descaled twice now, waiting four hours each time, as recommended by the Keurig website, and to no avail I still see particles floating in the fluid. I am at a loss as to what to do. I'd rather not buy another one, as this one still works, but I don't know what else I can use to help clean inside the machine other than vinegar. Any suggestions?
SOURCE: I'm having a flow problem with my keurig brewer.
you will need to give it a vinegar flush..white vinegar..I put about 1/2 cup with a full tank of water..keep running the water until empty..then run thru a full load of clean water..then taste some of the hot water..to see if the taste is gone....
you do not need to use k-cups for this
SOURCE: Descaled the Keurig - light still on.
Try running water through without the K Cup inside. My machine has the same problem and the "descale" message goes away after using this procedure. I am beginning to think that the bottom line on all of this is a pump that is steadily weakening.
SOURCE: A few days after descaling my Keurig (because the
Hi, Yes, it may take more then one time... Check out this tip about how to
descale your Keurig coffee brewer
How
to Descale your Keurig Coffee Brewer
heatman101
SOURCE: My 6 month old keurig
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
SOURCE: My Keurig brewer works good
heatman101
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
