Question about Panasonic VIERA TC-P50GT30 50-Inch 1080p 3D Plasma HDTV
PANASONIC PLASMA TV 50" shows black horizontal band across screen when turned on.
When we turn the tv on, a thick 2-3" black band appears accross the screen, horizontally. Eventually it goes away but it seems to be taking more time to go away.
4 Suggested Answers
tvservice306
  • 458 Answers
SOURCE: 2 white horizontal lines have appeared across my
check su and sd board or replaced......
Posted on Jul 23, 2010
easy-repairs
  • 43 Answers
SOURCE: my Panasonic plasma TV has suddenly developed a
it'll not be there when tv off because dead pixels do only show when back light of screen comes on, anyway if you still have a warranty then ask for them to check it out as it sounds like you need a new screen there mate
Posted on Nov 28, 2010
Slinteriors
  • 8617 Answers
SOURCE: I HAVE A PANASONIC 50" PLASMA TV IT HAS A HORIZONTAL 3 TO 4" WIDE LINE ACROSS THE SCREEN HOW DO I REPAIR IT MYSELF
sounds lie a couple bad drive Ics on the buffer boards. You can get replacement buffer boards and free technical assistance from www.tvrepairworld.com
Posted on Nov 28, 2012
Samsung startup problem
serial number on 6.17.8.1
Sep 21, 2013 | Televison & Video
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
73' Mitsubishi has magenta splotches moving around screen and eventually getting larger until whole screen is covered.
bad main digital board. It's the bottom board on the left, try Encompas Parts to get digital board.
Nov 27, 2011 | Televison & Video
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
May 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Panasonic VIERA TC-P50GT30 50-Inch 1080p 3D Plasma HDTV Logo
79 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
