Question about Omega MARS-22 Remote Vehicle Starter with Keyless Entry
I have a Mars Omega 343-02 suto starter- I locked myself out and had to use the key from the black box. After replacing it my truck won't start remotely. I need a diagram to see if the key is in p
  • 3 Answers
Here is the link for the installation manual
http://www.caralarm.com/manuals-install/MARS/MARS-33%20PLUS.pdf
Posted on Dec 28, 2013
5 Suggested Answers
  • 246 Answers
SOURCE: do the mars remote starters shut off your vehicles
ive installed many remote starters. ive never seen any that are wired into the fuel pump. they tap into your starter wire from the ignition.
Posted on Feb 17, 2010
Testimonial: "Thank you very much!!"
  • 5 Answers
SOURCE: I just bought an Omega Mars-22 from ebay. It came
antenna for extended range...
Posted on Mar 08, 2011
  • 21 Answers
SOURCE: looking for instale manual
http://www.caralarm.com/manuals/MARS/MARS-22.pdf
Posted on Oct 26, 2012
  • 21 Answers
SOURCE: How do I get the car back to be able to start with the key?
It sounds to me like your system is currenty programmed with the Anti-Carjacking feature turned ON.
If by chance it's an Omega/Mars system see page 11 feature #7
See page 12, how to program these features.
See page 15 for more info on the Carjacking feature.
Here is the link to get the manual
Posted on Dec 08, 2012
Mars 22 car starter. car starts for a second then turns off
Your truck most likely has a chip in the key. You will need to contact the maker of the remote start kit you have and see if they make a kit to bypass the chip key.
Nov 20, 2013 | Omega MARS-22 Remote Vehicle Starter with...
Dec 08, 2012 | Omega MARS-22 Remote Vehicle Starter with...
Truck starts then shut off then starts then shuts off its a mars but dont no what kind
Mine was doing the same thing. Find your Mars box, then...
Here is the link to get the manual. http://www.caralarm.com/manuals/MARS/MARS-22.pdf
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently.
Sep 08, 2011 | Omega MARS-22 Remote Vehicle Starter with...
How do you reprogram remote after replacing truck battery
Mar 02, 2011 | Omega MARS-22 Remote Vehicle Starter with...
Truck starts shuts off starts shuts off starts shuts off.
I had the same problem. Here is the link to get the manual.
See page 20/21 (picture)
Find your Mars box. You will need to turn either the Smart Start adjust screw or the Tach Wire adjust screw until the LED LIGHT is blinking consistenly.
Feb 07, 2011 | Omega MARS-22 Remote Vehicle Starter with...
After having the battery jumped the remote start does not work chevy monte carlo 2004 can you help
If it's a Mars 22---
Jun 18, 2010 | Omega MARS-22 Remote Vehicle Starter with...
My 2007 Ford Edge W/ Mars 22 remote start will start for 2 seconds when you hit the start button then shut off then start again then 2 seconds later shut off and will repeat this 2 more times, then will...
put your key in the ignition leave it in the off position, push your remote start button, if it starts then it has something to do with the transponder bypass "key in the box" or the loop around the ignition switch under the plastic cover
Feb 23, 2010 | Omega MARS-22 Remote Vehicle Starter with...
Changed battery in a 2003 chev. impala and now the mars remote starter will not work . what might be the problem
If it's a Mars--Here is the link to get the manual. http://www.caralarm.com/manuals/MARS/MARS-22.pdf
Jan 19, 2010 | Omega MARS-22 Remote Vehicle Starter with...
Have omega mars-22 goes through cycle like lock unlock doors security lights flash,but when you hit the start button on remote it does nothing,doesnt even try to start the truck worked fine before any help...
Try this
Nov 24, 2009 | Omega MARS-22 Remote Vehicle Starter with...
System will start car, but car will not stay started
Find the MarHere is the link to get the manual. http://www.caralarm.com/manuals/MARS/MARS-22.pdf
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently. s box, then....
Jun 11, 2009 | Omega MARS-22 Remote Vehicle Starter with...
Omega MARS-22 Remote Vehicle Starter with Keyless Entry Logo
253 people viewed this question
Top Omega Juicers Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Omega Juicers Vehicle Part and Accessory Expert? Answer questions, earn points and help others
