Question about ViewSonic PJD5122 3D Projector
Viewsonic PJD5122 projector has a horizontal black bar through the picture
There is a "blacked out" line through the top third of the picture. Everything else is perfect. Replacing the bulb did not fix the problem. It happens all of the time whether or not it's connected to a computer.
Marrie
  • 563 Answers
SOURCE: Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
Posted on Mar 26, 2008
SOURCE: Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Posted on Feb 11, 2009
projdoc
  • 2237 Answers
SOURCE: viewsonic projector pj501 - Has purple bloch with
2 issues- the light filter on one of the lcd panels is burnt due to excessive dust and heat. and one of the lcd panels is shot. time to replace the entire optical engine, unless you can get the prism assembly. otherwise, replace the projector. if you do, remember to keep it clean.
Posted on Nov 17, 2009
Testimonial: "Thanks for the help. Looks like the trash for this one!"
welcomejee
  • 10594 Answers
SOURCE: Viewsonic pj503d projector had "light
It seems problem with DLP Chip in projector that generates image to be projected. DLP Chip will be replaced by professional to fix this issue . I'm afraid it is not user level repair nor it is some sort of wrong settings in menu of projector.
It is hardware problem and professional can fix it. Please check with nearest tv repair shop or ViewSonic service center for fix.
Hope these info will help you.
Thanks.
Posted on Oct 30, 2010
SOURCE: I have my computer on
Assuming that you have all the connections between your computer and the projector already performed, you should check in you computer's manual what is the key combination necessary to switch between normal mode and presentation mode.
For instance, some Dell laptops and computers need you to press the function key (key marked with Fn in blue) and, while keeping it pressed, press also the F8 key (marked with CRT/LCD in blue) to cycle between the options.
Some HP laptops and computers will need you to do the same operation, but now using the function key and the F4 key, to select between "Computer only", "Extended (dual) presentation mode" or "Projector only" modes.
Some computers have an icon in the tray area at the bottom right part of your screen for the display characteristics. Clicking on it shows a menu where you can select the graphical options for your computer, and there must be an option for the selection of a dual display mode through which you can select computer + monitor (projector)
This same function can be called from the Control Panel in your computer. Assuming that you are using Windows XP, you will need to go to Start > Settings > Control Panel > (Graphics Adapter Configuration Setup), where (Graphics Adapter Configuration Setup) will depend on the graphics adapter chipset used in your computer (Intel, nVidia, ATI, VIA, etc). There, you might have the same options to select a dual presentation mode, to show the things in your computer display and/or your projector.
If even with these indications you are still not able to make your computer show its information through the projector, please send us more details on how you connected your computer to the projector, as well as the brand and model of your computer and the operating system you are using.
Hope this information can be helpful!
Posted on Mar 09, 2011
Why does my Viewsonic PJD5122 turn itself off after about 30 seconds of use?
Review your manual and check for a self-protecting power-off feature to prevent overheating. If it provides one, then you may have a fan that is out or became disconnected. Re-trace your steps when you replaced the lamp, you may find something that was not re-connected.
-GWOOD
Jul 15, 2014 | ViewSonic PJD5122 3D Projector
Green screen on VGA with Viewsonic PJD5122
VGA is separated analog signals in Red, Blue, and Green. Under normal cases, you'd be able to change the cable, source, or input port and resolve the issue. Unfortunately, if the green tint persists with all input ports on the projector (The two blue ones are Input, the black one is output. There is a potential that attaching input to the black output port could have caused the damage), different sources, and different cables, then it's likely a problem with the projector hardware itself and would require warranty service or otherwise repair or replacement of the projector. If you have an alternate way the projector can be attached, then try that (Such as SVideo), otherwise there may not be any good solution in this case short of checking the guts of the system.
Mar 28, 2014 | ViewSonic Office Equipment & Supplies
Horizontal black bar
Sounds like something is in front of the lamp?
Dec 03, 2012 | Optoma HD70 DLP Projector
How to make full screen instead of wide screen
That is a function of the media you are inputing. The black lines above and below are part of the picture comming from the media. Is that your question?
Dec 02, 2011 | ViewSonic PJ350 Multimedia Projector
How do i connect to cable tv to receive pictures from that source?
connect the video output from the cable settop box/decoder to the video input on the projector. also connect the sound signals as well
Jun 06, 2011 | ViewSonic PJD5122 3D Projector
A straight horizontal line right across the monitor 2 inches from top Not being connected to computer that is
Remove the back and check the ribbon cables on the left side that is in-line with the the black bar and remove it and on the other side of the cable there could be a couple of components that need ton be re soldered, or just clean the connections.
May 05, 2011 | ViewSonic VX2450WM Monitor
Hello my picture seems to have shifted upwards ie the top of the image is now at the bottom of the screen then there is a black line then the next two thirds are above the black line. I think on an old tv...
The problem was not actually the tv the fault was on the satellite box. I unplugged the box from the mains to reset it and the picture was restored to normal.
Oct 06, 2009 | LG 42LC2D 42 in. LCD HDTV
When first turns on, large black horizontal lines make picture unwatchable.
from possltd@hotmail.com the problem is the 3 thin ribbon wires that go to the lcd have become lose,or something else open top cover 6 screws 4 on the sides 2 on top must remove dark gray plastic piece have pic if needed Oct 4th 09
May 30, 2009 | Sony VPL VW10HT Multimedia Projector
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
ViewSonic PJD5122 3D Projector Logo
126 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
