Question about Blackburn Scorch USB Headlight 2013 - Light
Blackburn scorch light not charaging
Doesn't seem to charge with the USB charger. Can't get it to "blink" (did it the first 3 charges). Help???
My just bought Scorch only charges properly from1 of 4 tested computer's USB ports.
At home I have tested from 2 HP laptops and one desktop - it only charges for few minutes, then stops blinking. Once it stops, I cannot get it charging anymore, even if I reconnect it.
I bicycle to work and luckily I have there my work laptop - only there it charges properly until the battery is full.
What could be the issue??
Posted on Jan 13, 2013
3 Suggested Answers
SOURCE: after charging my blackburn led lights keep
Let it run for a minute or two, then shut it off and it should stop blinking.
Posted on May 10, 2011
  • 4 Answers
SOURCE: My rear flea light won't
it might be water damaged return it to bike shop and ask for full replacement under the lifetime warranty
Posted on Sep 28, 2011
MY BLACKBURN 1112V2 WON'T CHARGE
Unfortunately this has happened to me with no less than two of my Blackburn Flea 2.0 USB Lights. The good news is that they are warrantied for life. The only reason I still buy and recommend this product is because when it fails I simply return it to my local bike shop and receive a new one.
Feb 11, 2015 | Bell Sports Blackburn Flea 2.0 USB Front...
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
How long does it take to charge CCA 7000 battery ( car ) when I use SE-2158 battery charager wih 2 AMP/12 VOLT
2amp 12 volt is a slow charge it will take about 6 or more hours. when the needle on charger is down in green to full charge its fin. hope this helps
Sep 13, 2011 | SE3010 2003010 Amp Manual Starter and...
When i insert any sim card in my nokia 5230 it doesn't power on & when i remove sim from it, it works fine in offline mode & also having charging problem when i connect charger to mobile it...
it seems to be a hardware problem.give it to a authorised techinician. but before that we will have a try.try reinstalling your phones firmware using nokia software updater.it may solve your problem.else do wht i sais initially.
goodluck
Sep 09, 2011 | Nokia 5230 Cell Phone
Camera will not charge, shows blinking orange but will not turn on... when it does, it's to a "battery exhausted" screen or the lcd display with a low battery symbol. Also doesn't show on...
It could possibly be the battery or the charger itself.Try purchasing the charger it self.Use the old battery to see if it will charge it. If it does not charge you may have to purchase a new battery.as well.
Sep 06, 2011 | Nikon COOLPIX P100 Digital Camera
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
Dec 21, 2010 | Sony Walkman NWZ-E344 Digital Media Player
My Flea Taillight won't charge, I'm using a brand new "AA" battery, (hooked up - red to + and black wire to - ) I've reset the "light from demo mode (holding down the button for 20"...
Try cleaning the contacts with a cotton swab and som isopropyl alcohol.
Let those dry.
Use a paper clip, or other small pointy object to clear the area around the contact points on the light so the recharger can fully "snap" into place.
Attach a battery you know has a good charge.
Turn on the light.
Did the light turn on?
If so, great, turn it off, and if it is blinking, let it recharge.
If it didn't turn on, isn't blinking and won't hold a charge after this process, return it to Blackburn and enjoy the benefits of your lifetime warranty.
May 08, 2009 | Blackburn Flea Rear Flasher Bicycle...
Blackburn Scorch USB Headlight 2013 - Light Logo
314 people viewed this question
Top Blackburn Cycling Experts
John Egan
John Egan
Donald Ayers-Marsh
Are you a Blackburn Cycling Expert? Answer questions, earn points and help others
