Question about Creda Ovens
Creda europa solar plus manual replacing grill element
Model 48145
SOURCE: re creda europa solar plus no insrustions for cloak/timer
Look here, it is a different model, but the clock is the same
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Creda/Cooking/HB48904_489000069-05.pdf
Posted on Jun 22, 2009
barkencoa
  • 3463 Answers
SOURCE: Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Posted on Dec 08, 2009
  • 157 Answers
SOURCE: I need a new element for my Creda fan oven but
what do you want model creda concept 46307
Posted on Mar 09, 2010
barkencoa
  • 3463 Answers
SOURCE: Hi.I have a creda europa
You need to replace the fan oven element located at the rear of the oven compartment behind removeable cover.
Posted on Sep 24, 2010
SOURCE: creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Posted on Sep 26, 2010
Creda oven manual
The heat control knob needs to be replaced. This controls the amount of electricity that foes to the burner. Sometimes the burner itself has too much resistance and will only work when full current is applied. Hope this helps, please post a comment that this is solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
May 10, 2014 | Ovens
Creda Europa Oven an Grill Big oven has Stopped working what would be possible causes
do you mean there isnt any power going to it or it dosent heat up or it just gets warm more detail please
Dec 05, 2010 | Creda Europa E010E Electric Single Oven
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
Hope this helps.
Dec 08, 2009 | Creda Ovens
Oven problem
Check that the solar plus grill element is working properly by selecting full grill, the whole element should heat up, if only half element heats up , then you need to fit a new grill element complete.
If the grill element is o/k , then it is possible the top oven base element is faulty, to check that is working, put top oven on and after a few minutews feel the base of the top oven, and it should be hot to the touch if it is not, then the base element has probably failed , and you will need to fit a new one.
These are the possible reasons for it to heat up slowly.
Plz rate my solution.
Thanks.
Jan 25, 2009 | Ovens
Ovens Logo
94 people viewed this question
Top Creda Ovens Experts
ashburton
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Creda Oven Expert? Answer questions, earn points and help others
