Pyrox model 114-Gas valve and solenoids require replacement, are these parts still available
2 Suggested Answers
SOURCE: Require fan for pyrox lpg
THANK YOU FOR THE REPLY
NOT MUCH OF A PROBLEM WILL CONTACT YOU IF WE NEED TO FOLLOW UP.
Posted on Aug 20, 2008
Runs but not getting hot
check the gas supply pressure. if not within required pressure consult the gas company. if there is no problem with gas pressure get to the back of the unit to check the fuse for the gas solenoid valve that controls the flow of the gas. if solenoid valve is faulty, replace it with a good one . . if after installing a new solenoid valve unit still does not kick in , check the igniter . replace with a good one if it is broken , the unit should produce heat now .thanks.
Feb 26, 2016 | Whirlpool LGB6300 Gas Dryer
Machine fills while idle
A very likely cause of this is an inlet solenoid water valve inside of the machine is leaking. The risk is if left unattended the water will over fill and end up on the floor. Secure the inlet valves where the hoses connect to the wall. Make sure that the valves are closed.
This repair requires an experienced technician to replace. The parts are readily available. To use the machine supervision of the wash process is required. The solenoid vales in the machine can not be trusted and you should assume that they may fail allowing water to overfill at an increased rate.
At this point when ever the machine is not in use the vales need to be closed. If the solenoid valve has leaked even once it can not be trusted.
Dec 30, 2015 | KitchenAid KHWS01PMT Front Load Washer
Trying to locate replacement parts for my gas wall heater
http://www.enviro-friendly.com/bonaire-gas-wall-furnaces.shtml
Bonaire pyrox is the old Vulcan company
Standard Appliance Parts Sacramento California can get you anything you need as well.
Apr 05, 2015 | Vulcan Heating & Cooling
Got a P0456 engine code. Also leaking about 1/2 cup water overnight under the engine area.
You have to smoke test the evap system & use a scan tool
& follow trouble charts to diagnose
That has to be done by a repair shop--- otherwise you just throwing
parts at it
Nov 30, 2012 | 2002 Dodge Intrepid
Pyrox natural gas heater not functioning properly
Clean the burners out with air pressure,like from a air tank,and a blow gun,then clean the pilot light orifice(this is where the pilot light is)if this does not help,replace the thermocouple ,it will be the problem,if this was at all helpful,please rate,thank you.
Jun 15, 2010 | Heating & Cooling
Hi I am looking for just the solenoid portion
I doubt that you will be able to obtain one. Those sorts of parts just aren't available.
Nov 13, 2009 | RTO Suburban Rv Water Heater Dsi Gas Valve...
My gas dryer ignitor heats up and then I hear a
I would suspect faulty gas valve coils or a faulty high limit thermostat, based on what you have described. First, the high limit thermostat is a round, black device mounted on a metal plate and is usually attached to the internal ductwork with two screws. It can be tested for continuity using a multimeter. It should have no continuity. If it has continuity, it is stuck and faulty. The black electrical coils are right above the gas valves and when these solenoids are energized, they open the gas valves and allow the burner to light. If one is faulty, the valves don't open and the burner can't light. If the ignitor is operating properly, they would be the likely fault. Due to the difficulty in testing these solenoids, it is recommended that if they are suspected of being the fault, that both (all) of them be replaced at the same time. Hope this helped and best wishes.
Aug 07, 2009 | Dryers
Cannot find solenoids
First, unplug the appliance and turn off the gas.
You will need to lift the top panel of the dryer by pulling it towards you and lifting up. Sometimes placing a putty knife in the seam at the point where the retaining clips are along the front, will help to release it.
With the top panel released, disconnect the door switch connector wires and ground wire on the front panel. Remove the two screws that hold the front panel to the side panels. There will be one on each side. The front panel will lift up slightly, and off, exposing the dryer interior.
Release the belt tension for the idler pulley near the drive motor and lift the drum (with the belt attached) out of the cabinet. You should now have full access the the burner assembly.
Go to searspartsdirect.com and type in the model number you provided. Look under the "Burner Assembly" heading for items 13 and 14. These are the gas valve solenoids you will need to replace. I don't know where the previous quote came from, but these solenoids do not cost any where near $200 dollars. It is highly recommended that you replace BOTH of them at the same time. The part numbers are 694539 and 694540.
NOTE: You can also find both these parts at appliancepartspros.com for much less. Use the part numbers I provided and use the "Search by Part Number" feature. I still referenced the Sears website, because they offer excellent exploded view diagrams you can use to assist you. I could not find your model number listed on the second site, but the part numbers are still available.
If you still have questions, please let me know. I hope you find this information helpful.
Jan 16, 2009 | Kenmore 73952 Gas Dryer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
