Question about Kitchen Ranges
When trying to light oven, broiler & self cleaning none of them will light until it finally clicks. What causes that click sound, I think I need to replace that part.
    Problem Solver:
  • 17 Answers
No the clicking sound your hear is coming from your spark module. thts a sound u need to hear on newer gas appliances...
Posted on Dec 13, 2012
jsrock516
  • 5911 Answers
SOURCE: broiler quit
Have you checked the broil element resistance? Unplug the range and remove the back cover. Remove the wires from the broiler element and place a meter across the element posts. See if the element reads close to a short (It should read very low resistance if good). If the element reads infinite (open), you will have to replace the broil element. If the readings are normal, you may have a bad Electronic Range Control (ERC) board. The board controls the bake and broil features of the oven through two separate circuits. Usually a relay on the board goes bad. Since the ERC is considered "non-serviceable", replacement components can be hard to find. For this reason, the entire assembly is usually replaced. The ERC runs around $100 for your range, while the broil element can run anywhere from $35 to $60. Now...as far as your self-cleaning function is concerned - most electric ranges use BOTH elements to super heat the oven cavity to about 700 - 800 degrees F. With one of the elements not working, there's a good possibility the self-cleaning function will not work either Double check the items I mentioned and let me know if this helps you.
Posted on Feb 02, 2008
  • 161 Answers
SOURCE: GE profile glass stove top
You got one or more of the burner switches wet. (It usually happens when you wash the knobs and water stays in the holes until you replace it on the shaft) If just water they may work after a day or two. try using a hair dryer, Keep it at least 12 inches away. If oven cleaner or other chemical got inside switches they may need to be replaced. If you can't dry them out. Disconnect the wires from all but one switch at a time and see which one/s need to be replaced. Sometimes the electric part of the switch can be seperated from the gas part and replaced seperately. DO NOT LEAVE THE STOVE PLUGGED IN until you fix this problem. There have been reports of fires started from this electrical problem. You could also burn out the spark ignightor. The fire problems have been mostly with Maytag/Jenn air products but my whirlpool blew a fuse and shot sparks when this happened to me. I just replacet the whole cooktop as my gas valves were one piece units and way to expensive to repair.
Posted on Jun 29, 2008
SOURCE: maytag gemini self cleaning oven feature
Close door on lower oven (upper oven is not self clean). Press "Clean" pad. Press More pad or Less Pad. H is 4 hour clean, M is a 3 hour clean cycle and L is a 2 hour clean cycle. The door will lock and cleaning will begin. Good Luck!
Posted on Dec 08, 2008
freetek
  • 5568 Answers
SOURCE: Oven and broiler will not light.
You've probably done this by now since your message is May (makes us a May-December couple??) but wanted to write that the transformer that produces the park for ignition has failed.  I don't know how accessible it is in your unit, if you check on Sears website under Parts with your model # in hand, they could well have an illustrated breakdown of your range which would give you an idea of how difficult the replacement might be.
Posted on Dec 28, 2008
  • 22 Answers
SOURCE: Self Cleaning light comes on and flashes when you turn on oven!
It sounds like you have a defective Oven control module. (TO8 Control) is the part that controls all oven functions including clean,clock,timed bake, ect. Item is easy to replace yourself.
Posted on Mar 30, 2009
Kenmore 790 oven won't heat after self clean
Did you fully disconnect the wires when you checked continuity? If not you are checking continuity in the whole circuit. For what its worth, the self clean feature superheats the oven and often burns out elements. We see it all the time. It is one feature to never use!
The broiler element is not part of the oven temperature, it is a broiler. The oven works on the bottom element alone. If it only gets to 300'F, wither the bottom element is faulty or the thermostat is failing. As I mentioned self clean is a great way to cause problems.
Nov 16, 2017 | Kitchen Ranges
After putting my 10 yr. old Whirlpool Model RBD276PD double ovens thru the self cleaning cycle the bake and broiler elements in the bottom unit stopped heating. All the controls on the panel work and the...
This sounds like it blew the thermostat on the back of the lower oven. They are inexpensive and easy to replace. You will need to uninstall the unit and remove the back panel to acess. Check it for continuity if none replace. This is a fairly common failure due to the heat of the self cleaning. Here is a link to your part and diagrams are also available there AP3055316
Sep 28, 2010 | Ovens
Oven will not reach desired temperature and slight gas smell
Just had same problem it was nice it waited until christmas dinner, all i did to resolve the problem was switch the upper broiler igniter with the lower one for the oven. I tuned on the oven & it fired right up i never use the broiler on my oven so itll buy me some time. So if you can get the broiler to light try that but i did have the same low temp. & the smell of gas. Good Luck
Jul 29, 2010 | KitchenAid KGRT607 Gas Kitchen Range
I have model GS563LXSS...all of a sudden the oven
It is not good to do the self clean. The electronics take a beating. Probably the ignitor went out. The oven gets too hot.
Nov 03, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
I cannot get the auto self clean cycle to end
It sounds like your oven control module is bad. It conrols all bake, broil, including self clean.
Mar 25, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Oven
Hey ascollins217
This is normal with a gas range. The oven is lit with an ignitor (the glowing that is seen) - it glows first then the gas comes on and lights up shortly afterwards. There is no clicking sound for the oven (at least not for the model you have)
Regards
Sep 06, 2008 | Frigidaire FGF316 Gas Kitchen Range
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
