I have a question will the washer still agitate if it has a bad thrust bearing yet it will not spin out
    Problem Solver:
  • 7 Answers
You could replace thr bearing but Iwould check the drive belt first.
Posted on Dec 13, 2012
  • 30 Answers
SOURCE: Agitator problem
Check to see if any thing is under the agitator. If not then maybe the bearings going out or other part of machine . Besure the cap is tighten so agatator don't come off. Check for ware on agatator top to the tighting nut.
Posted on Jun 02, 2009
  • 240 Answers
SOURCE: INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Posted on Apr 28, 2009
  • 61 Answers
SOURCE: Replacing maytag thrust bearing kit 12002213
yes you can do it yourself no special tools are need just a couple good flathead screwdrivers and a lot of patiance be sure to put all the new washers and bearing back on in the same order the old ones came off putting the C clip on can be a little tricky but take you time and it can be done you may hvw to use the flat head to pry on the trans. shaft to get the clip in the groove then use a pair of chanell locks or pliers to snap it on if you get a new style bearing it may not look like the one you take off and not have all he washers just snap the small plastic pice onto the bearing put it on the the pulley the most of the time just the thin washe then the C clip the dust cover put belt back on the test machine
Posted on Jan 20, 2009
Macmarkus
  • 2605 Answers
SOURCE: washer making rattle noise during wash and spin cycle
I would agree with that diagnosis. That is a symptom of a worn thrust bearing for sure and it is a quite common occurrence on your style of washer.
I wouldn't rule out debris in the drain pump as another possibility as well though, i.e. small stones, jewelry, etc. You may want to rule out that possibility before throwing money at a pulley & thrust bearing kit ( it is actually a "transmission pulley kit" which comes with a new thrust bearing as well ). part # 12002213 and retails for about $40-$50 see photo's below.
Hope that answer's your question. Let me know if I can assist you further and thank's for visiting "fixya" for your repair inquiry. Please take a second and rate this info I provided for you here.
Good luck.
macmarkus :)
Posted on Mar 17, 2010
  • 72 Answers
SOURCE: NOISE DURING SPIN CYCLE
You have to take the tub out, take off the rotor from the bottom of the washer, remove 4 bolts and take off the stator, take off the bearing retaining nut, then drive the 2 bearings out with a drift. I bought the bearings online for 20 bucks from a supplier (VBX). They are standard metric bearings number 6005 and 6006. I put some silicone grease on the shaft seal and drove the new bearings into place. Then reassembled, and the washer is whisper quiet.
Posted on Feb 04, 2011
Amana nav5805aww washing machine won't spin
You will need to replace the thrust bearing kit. Here is the part to order.
It comes with the instructions and is an easy fix.
Oct 30, 2012 | Amana NAV5805A Top Load Washer
Washer makes loud grinding noise during agitation and does not agitate - it is a maytag atlantis.... fix or replace?
I suspect the thrust bearing kit is bad. This comes with great instructions and is easily replaced. I would recommend changing this before replacing the machine. You are not out much if it does not work, but I am confident you will get it going by replacing this! This is a VERY common problem with these washers and the new kit has been redesigned.
Kelly
Mar 21, 2011 | Maytag Atlantis MAV9750A Top Load Washer
My Maytag performa washer will not agitate or go into the spin cycle. It makes a loud noise instead
From what you're describing I suspect the thrust bearing needs replaced. The thrust bearing is what releases the brakes. You will not be able to rotate the basket manually with the brakes set. I recommend replacing the thrust bearing kit part number
Jan 10, 2011 | Maytag Washing Machines
I have a magic chef 20 lb capacity heavy duty washer model W20HN3S serial ME851474 with spin problems. Clothes come out soaking wet. Can I replace a belt?
If your washer will wash (agitate) your clothes but does not spin well, you will need to replace the "thrust bearing" in the washer. The repair is simple and will only take you a short to do. Here is a link to the "thrust bearing kit" you will need.
Jan 07, 2011 | Chef Cooking Magic Chef Washing Machine...
The motor runs but will not spin out
You either have a bad transmission - worst case - or you have a bad thrust bearing. Remove the belt and rotate the drum pulley CCW. The pulley should push the thrust bearing upwards, releasing the brake, and engage the transmission. If it doesn't you have a bad thrust bearing. It comes as a set, pulley and bearing. It's a easy job. If it is engaging transmission and still no spin then your trans can be bad.
Rich
Western Appliance Repair
Meridian Idaho
Dec 02, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag PAV2300 - Washer agitates during wash. on spin cycle motor runs and belt is fine, but drun does not spin. Water drains. Why does it not spin?
Hi, The most common problem is the thrust bearing kit. The thrust bearing is located on the lower shaft of the transmission. The kit includes a new pulley and hardware. The part #12002213 also includes instructions.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 13, 2009 | Maytag PAV2300 Top Load Washer
Washer won't spin or agitate
jesus crist remember all the work that machine did for your family and forbiden it, it sound to me to be the transmision, but wait for catriver, gona tell you somes tips, put your hammer in the closset by now..good luck
Aug 06, 2006 | Maytag Performa PAV2200
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
