A message can on the tv "check fan No 1"
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The message means the set has detected an issue there, the fan may or may not be bad. See a lot of this and half the time the fan is good.
Posted on Dec 13, 2012
Where is the fan located and what is the check procedure?
remove the back cover u will see the fans one for the ballast and the other for the lamp
Jul 10, 2013 | Samsung HL Televison & Video
Where is "fan #2" in Samsung dlp hl-r5656w?
I don't know which is fan #2 but if you take the back off, you will see one fan right in front of you. The other is harder to get to. It's the black box inside the silver covering with the holes (in left lower part).
My TV was acting up by having only one color showing until I let it cool down then it would work fine. I cut a hole in the plastic back cover and mounted a bigger computer fan. Just spliced it in the wires of the little fan. Fixed the problem
Jan 26, 2013 | Samsung HL-R5656W 56" DLP HDTV
Is there any solution for "check fan 1" Samsung LN40A650A LCD TV
Just fixed my Samsung LN40 check fan #1.Unplug, Take the back off (like 20 screws were hard to find them all) fan is exposed in the middle. Unscrew fan, used q-tips and nozzle tool on vacuum cleaner to remove built up dust gunk. Blew in center of fan to dislodge dust. Screwed fan back on, plugged in to see if fan was spinning to cool TV. It was and the check fan message disappeared. Put the back on. Feeling Lucky no big repair.
Nov 26, 2011 | Samsung LN40A650A LCD TV
I have a 61 inch samsung TV. A message flashed across the screen saying "check fan # 1 " then a few minutes later it shut down.
Hello
Not much to do by web, this message mean you most likely need a new fan, tv shuts down due to overheating. Contact service.
Aug 21, 2011 | Samsung Televison & Video
I have problem with CPU fan. The message I get is "Low speed " a think. Sometimes my computer off. What is the problem. Do I need to replace the fan? What the normal fan speed to be desplayed in...
If you have not checked the fan for dirt etc, then do so. Sometimes it might just be the dirt that is slowing it down.
If all that is ok then refer to this manual on page 2-35 to find out which fan is causing the problem using the BIOS commands.
You can replace the fan if necessary but once you identify if there is a fault.
Jun 20, 2011 | ASUS A8N-E Motherboard
Our Samsung TV model HLT6187SAX\XAA is displaying a message on screen "Check fan # 2" Red and green lights on the lower right front are flashing. What does this mean?
There is a bad fan in your T.V. You would have to open it, see which fan isn't spinning, get the part number for the fan, order it and replace it.
Jun 19, 2011 | Samsung Televison & Video
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Not always but most of the time , after working propely i can ear the fan(s) going stronger for few seconds, a message "ERROR MESSAGE CONDITION2" appear , the TV(monitor) shut down, and the power...
hi,
check the fans first. i may have some problem. i think the fan may be not attaining its regular speed. it can happens because of the wear and tear of the bearing of the fan. thats why the temperature is going up and shut the tv off. replace the fan and then try again.
ok
Dec 31, 2010 | Fujitsu Plasmavision PDS-5002 50 in....
Message on my tv reads check fan 1..
check fan 1 means the fan is not cooling, check to variety the fan is indeed working, the unit is shutting down due to over temp. if there is a filter, clean it
Jan 30, 2010 | Samsung Televison & Video
Optoma RD50 TV which shuts down on #1 fan failure
This could be a variant of, or a newer (or older) version of the "DMD fan failure" message.
Symptoms I had are, I stop hearing a fan when the message is displayed.
Then the temp LED keeps flashing RED until I either try to turn the TV on again,
Or turn MAIN power off/on again. BUT it repeats when I try to turn the TV on.
The picture appears normal until this happens ( about 15 sec.)
The solution is to FORCE a normal shutdown by hitting the TV off button
before the message appears.
You should see the power LED flashing RED/GREEN (cool down) and then RED (standby).
Apr 20, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
