Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
My Sharp Aquos 46 inch Digital TV has crackling sounds like a short in the electrical system.. is this dangerous
The television will occasionally suddenly have a crackling sound and a boom sound
    Top Expert:
  • Sharp Master
  • 14,553 Answers
If it is doing this it could cause more damage, either in the sound circuit or elsewhere, do it with sound off?
Posted on Dec 13, 2012
  • shark139
    shark139 Mar 28, 2013
    I have the same problem with my Sharp Aquos LC-46LE730E. It happens with all devices connected to the TV - digital cable broadcast, Xbox 360, DLNA media playback, PC etc. Are there any ideas about it? Thanks in advance.
  • 4234 Answers
SOURCE: analog to digital conversion on Aquos?
First of all, the change is actually goping from analog over-air broadcasting to a digital signal. Second, if you have cable or satelite, you don't need anything. The only time a converter is required is if you use rabbit ears or an external antenna. In your case, the TV DOES have a digital tuner so you DO NOT need a converter in either case.
Dan
Posted on Sep 23, 2008
  • 54 Answers
SOURCE: I can not remove the stand from my aquos 46 inch tv.
you will find 4 screws at the back of the tv about 4" inches from the bottom. lay the tv set flat on your bed. you will need a metric allen wrench to remove the 4 screw. once the 4 screws are removed slide the base away from the tv.
Posted on Jan 19, 2009
SOURCE: Audio Problems with Sharp Aquos T. V.
Just talked to a fellow at Audiotronics regarding Sharp Aquos.
This is a widespread problem with audio on their TV's, The tech. said there may be a full recall regarding this problem!!!
Posted on Oct 19, 2009
  • 8457 Answers
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
micromatikal
  • 2777 Answers
SOURCE: Failed to receive broadcast E202 Sharp
What do you mean exactly when you say "failed to receive broadcast"? Does it not get a signal of any sort? What about from DVDs, do you have a DVD player attached, does that work? Did it used to work just fine with regular TV signal?
Thanks, let me know more and I can definitely help!
Tim
Posted on Sep 29, 2010
Crackling front speaker
kinda over driving it heh??
Mar 14, 2014 | Peavey PR15 400w PA Speakers
Protron tv crackling sound
The speakers that are inside your tv are damaged and needs to be replaced, after you replace your speakers, the Sound will return at the correct factory settings from which you received your tv..
Feb 10, 2013 | Protron PLTV-37 37 in. LCD Television
TV does not respond to remote
First of all... forgive me me if its a dumb question. But... How long has it been since you changed the batteries in the remote?
Jul 05, 2012 | Sharp AQUOS LC-40LE810UN 40 inch...
Sony Bravia KDL46W4150 crackles and volume suddenly increases
Hello
There is some loose solderings or leaky ceramic capacitors at the audio output section of your sound card. Check it.
Feb 28, 2012 | Sony BRAVIA KDL52XBR2 Television
We have a new 46" Sharp Aquos with a "snowy"
sounds like you have a cable connection problem make sure your tv is set to dtv signal in the menu screen. when you scan the channels should be displayed as 12.1 or 8.2 not just a single number if the digital channels are programmed correctly then change the cable coming into the tv from antenna making sure that it isnot crossing any power wires good luck and hope that i helped
Nov 07, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Have a red blinking light on tv tv does not turn on
Normally one red blinking power indicator means your television needs a main board and or a power supply. The television would need to be evaluated and if you need a power supply only perhaps the service provider can rebuild it for less than $200. If the television needs a main board perhaps Sharp will work with you if you have an estimate. If you really have an aquos television 46 inches or greater you can get assistance at 877-332-7867
Aug 19, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Crackling sound, with occasional loss of sound
Let verify first to narrow down to where the problem can be, attach the powered PC speakers to the Audio Line out RCA jacks to see if you get the crackling sound there also, if you do, then the problem is in the sound processor circuit. Please post back what you find. If not, then the power section is bad. If you can live with sound from the Powered speakers, you may want to keep on using it that way, just muted the speakers in the sound setup menu, otherwise the repair bill can be in the $200~300 range.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 06, 2010 | Protron PLTV-4250 42 in. LCD Television
Sound but no picture
You will need to perform a factory reset/INIT on your television. Call 877-332-7867 for assistance. You will need to complete a case file with the customer service representative first and then if he or she cannot walk you through it you will need to speak to an aquos advantage dispatch representative. You can call anytime between 7AM and 9PM CST but the dispatch representatives go home at 7PM CST.
May 06, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My 37" TV
if the set has a headphone socket try that with some headphones if noise vanishes then is probably a loose speaker nacelle if noise is in headphones this is a set issue check all connections are good my set occasionally gets a loose hdmi connection this affects the sound badly.
Feb 17, 2010 | Akai LCT3785TA 37 in. LCD HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
258 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
