Question about Pride Mobility Jazzy 614 HD Power Wheelchair - Used Power Chairs
Batt charging indicator lights, dont all come on
  • Pride Mobility Master
  • 1,263 Answers
Have you tried another charger ?
Regards
Posted on Dec 13, 2012
My blue dash 5.0 phone won't charge I plug it up and it says its charging but it dont
Check its battery. Most phones will indicate charging even on a fault batt. But when you start it, no power. If it's persistent consult a technician.
Mar 23, 2015 | Cell Phones
My engine cuts out when I put lights on where would the problem be
it could be u have a batt charging problem , so check out for more than 13 volts on batt leads with/out lights.
U should also disconnected the batt leads and make sure they r clean and tightly fastened .
Check out for water level if u dont have dry batt .
Feb 23, 2015 | kawasaki EL 125 Eliminator Motorcycles
G'Day.. I have a Plega Traveller, (it no longer
Sounds like one or both of the batteries has a high internal resistance. Bad batteries, perhaps? Have you LOAD tested or tested for internal resistance? Could be why charger is shutting off so soon.
Voltage isn't the only test for these types of batteries.
Oct 24, 2013 | Health & Beauty
97 checvy astro 4.3 6cyl. I replaced battery, Starter and the batt wont hold a charge. Is it possible to check the wiring from the alt to the starter without having to remove the alternator?
Yes, If you have a volt meter, jump and start engine, with engine running you should have approx 13.5 to 14.2volts that would tell me that batt is getting charged when engine is running. you said new batt would not hold a charge, I would be thinking about a parasitic draw(small amount of power) that in time will drain batt. things to look for are glove box lights, under hood lights that dont turn off. one easy way too see if you have a draw is to disconnect one batt cable, now use a regular (12volt non-self powered) test light and touch one end to batt cable and the other to empty batt terminal, with no light switches on and doors closed, this test light should not light and if it does then you have a drain on batt that will kill it say overnight.
Feb 12, 2011 | Chevrolet Astro Cars & Trucks
When car sits for more than 1 day battery is dead
either your batt went bad or car not charging batt. beyond that i look for trunk, dome or under hood lights that dont shut off slowly drainng batt.
Jan 29, 2011 | Mercury Cougar Cars & Trucks
Charging system light came on but batt has 12.9 volts after running for about 40 mins with indicator on
With the vehicle running the battery voltage should be at 14 volts, if you take it by advance auto they can hook it up to a tester without removing it from the car and they dont charge for this service. I hope this helps you.
May 24, 2010 | 2005 Ford Taurus
I have plugged the Soneil battery charger into the MPV4 Hoveround for over 24 hours. Although the indicator shows charging in process, the "battery charge indicator" shows it still requires a substantial...
If your Power Wheel Chair has been sitting idle for a while, the batts may need to be completely replaced. There is a gel inside the batts that need to have a current run through them via the charger on a regualr basis otherwise it will solidify. If the charger lights are onm you have connected the charger correctly for over 24 hours and the batteries are still not showing they have been charge, there may be damaged cells which means both batteries need to be totally replaced.
Nov 01, 2009 | NRS Hoveround MPV 5 - Used Power...
Never held charge more than a few seconds
you need a new battery This one is a dud
Jun 28, 2009 | Garmin nuvi 750 GPS Receiver
Why won't my charging light come on when I try to charge?
hi
Try to leave it on charge for a 24 hrs. If the batt gets below a certain voltage the charger will not come up to fast charge rates(light on) to prevent damage to the batt. If it does not take a charge, it is possible that it is faulty. If you have been using the batt regularly and it suddenly stopped taking a charge, it may be the charger at fault. If you you have not used the batt for a while, it may be faulty. only way to really check for sure is to try a new batt. If you have any more questions about it, just ask away. Good luck
regards
robotek
Aug 05, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Pride Mobility Jazzy 614 HD Power Wheelchair - Used Power Chairs Logo
47 people viewed this question
Top Pride Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Scooter Doctor
Scooter Doctor
Are you a Pride Mobility Health and Beauty Expert? Answer questions, earn points and help others
