Question about SAMTRON 55V 15" CRT Monitor
Samton56V white balance alignment
I have replaced the CRT of Samtron56V. How can I align the white balance.
First you adjust eht screen voltage and focus control
Posted on Apr 14, 2009
Do I need a wheel alignment when changing your old rims and tires for a new ones?
No alignment needed unless replacing suspension/ steering components
Jun 30, 2015 | Cars & Trucks
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Do I need to the do the wheel alignment after wheel balancing or the other way around?
They are really separate issues, but in my opinion I would do it just as you did, the balancing after the alignment. The alignment adjusts the wheel assembly to assure the tires wear evenly from side to side, and eliminates wheel scrub (toe in or toe out) along the inside or outside of your tires. The wheel balancing makes the tire rotate evenly to eliminate flat spots as it rotates so your tire wears evenly all around.
May 21, 2014 | Vehicle Parts & Accessories
What is white balance
White balance is the camera looking at the whitest white and the blackest black and aligns all the other colors between the two digitally. when you adjust the white balance you create end points for how light the lightest or darkest point in your photo can be collected on your camera.
May 01, 2014 | Panasonic Lumix DMC-FX12 Digital Camera
Set timing on a 98 honda civic dx
"The crankshaft timing pointer must be perfectly aligned with the white mark on the flywheel or flex-plate; the camshaft pulley must be aligned so that the word UP is at the top of the pulley and the marks on the edge of the pulley are aligned with the surfaces of the head.
Install the timing belt over the pulleys and tensioners.
Loosen the bolt used to lock the timing belt tensioner. Loosen, then tighten the timing belt adjusting nut.
Turn the crankshaft counterclockwise until the cam pulley has moved 3 teeth; this creates tension on the timing belt. Loosen, then tighten the adjusting nut and tighten it to 33 ft. lbs. (45 Nm). Tighten the bolt used to lock the timing belt tensioner.
Realign the timing belt marks, then install the balancer belt drive sprocket on the crankshaft.
Align the front balancer pulley; the face of the front timing balancer pulley has a mark, which must be aligned with the notch on the oil pump body. This pulley is the one at 10 o'clock to the crank pulley when viewed from the pulley end.
Align the rear timing balancer pulley (2 o'clock from the crank pulley) using a 6 x 100mm bolt or rod. Mark the bolt or rod at a point 2.9 in. (74mm) from the end. Remove the bolt from the maintenance hole on the side of the block; insert the bolt or rod into the hole. Align the 2.9 in. (74mm) mark with the face of the hole. This pin will hold the shaft in place during installation.
Install the balancer belt. Once the belts are in place, be sure that all the engine alignment marks are still correct. If not, remove the belts, realign the engine and reinstall the belts. Once the belts are properly installed, slowly loosen the adjusting nut, allowing the tensioner to move against the belt. Remove the pin from the maintenance hole and reinstall the bolt and washer.
Turn the crankshaft 1 full turn, then tighten the adjuster nut to 33 ft. lbs. (45 Nm). Remove the bolt used to lock the timing belt tensioner."
" " Chilton Library
Apr 27, 2012 | 1998 Honda Civic
I have a 99 ford Taurus and i will change the ball joint '' both sides'' so do i have to do front alignment and wheels balance ? Or i just can do the front alignment ?! Thank you so much
You will not have to have the wheels balanced but an alignment is a good idea.You are not affecting the balance by changing the ball joints
Nov 02, 2010 | 2001 Chevrolet Malibu
When I am going about 60 miles per hour the car doesn't run smooth, feels shakey. My tires were replaced in the front about 6 months ago.
if its just at that speed, have the tires balanced again, and get a front end alignment ,, a single bump on a curb can knock it out of alignment
Aug 02, 2010 | 2001 Oldsmobile Aurora
Red and blue color on TV is aligned but blurred, green is ok
U have a CRT Tube coolant problems.Tries Websites MCMElectronics.com,Tv reapair World.com to buy CRT tube coolant to recharge ur CRT.
Feb 26, 2010 | Sony KP-46WT500 46" Rear Projection...
BMW vibration in steering even after alignment, balance and control arm replacement.
Does it vibrate all the time at 60 or only when you apply the brake?
Apr 29, 2009 | BMW 528 Cars & Trucks
SAMTRON 55V 15" CRT Monitor Logo
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
