Question about Toys
Having trouble with this flying! Any ideas? - Toys
  • 3 Answers
Check the calibration. check it if balancing rod is missed. check if hairline crack in rotors
Posted on Aug 24, 2014
Hi all im using Canon SX260 HS which have gps and altitude feature. Im having problem where the altitude reading is not accurate. Any idea why is this happening or anything i can do to make it right. Using...
I think this has to do with the limitations of the GPS device build in your Canon. The device is not build to fly in a plane. You are moving to fast. I'm convinced if you are on a mountain the device will have no problem displaying the correct altitude. And when in a plane, the small antenna inside will have trouble finding good signals. Look what the Canon does, while you are still on the ground. See if it finds enough satellites in a short time. Check if the airplanes body works as a shield.
May 13, 2014 | GPS
My dh9118 needs the bottom blades flipped but i can't take out the screw for the shaft,
It's been a while, but i believe i remember reading that some of the blades were held by screws that were turned clockwise to loosen.
Or were you having trouble getting the screwdriver to fit in the head of the screw?
Sep 25, 2017 | Toys
Power light comes on .cant do above 35
This is normally a problem with the fly by wire throttle system. there are several reasons this can occur. the most probable cause is the throttle body itself is either extremely carboned up causing the throttle plate to stick, or the throttle body itself is bad. you will need to have the system scanned for trouble codes first. the trouble code will give you a much better idea where the fault is. if you jusr want to try a easy repair, try cleaning the throttle body out with some throttle body cleaner.
Sep 18, 2011 | 2005 Chevrolet Colorado
I am replacing the strut/spring/bearing housing on the front end of my '95 grand am. Having trouble removing the large BOLTS that connect the entire assembly to the spindle. Are these bolts fully...
HI, you almost figured it out. Those two bolts have splines on the upper portion of the bold shank. Once you have the nuts removes you can take a small 2 or 3 lbs. hammer and give the bolts a couple quick hard hits that should drive them out. Its a good idea to hang a shop rag or old towel from the strut down over the bolts to keep them flying out. Good luck
Aug 28, 2010 | 1995 Pontiac Grand Am
I am having trouble simplifying ratios on the FX-83ES. Any ideas? For example 10:5 should come up with 2:1, but it comes up with 10 when I press =.
am having trouble simplifying... Solve I am having trouble simplifying ratios on the FX-83ES. Any ideas? For example 10:5 should come up... (More) I am having trouble simplifying ratios on the FX-83ES. Any ideas? For example 10:5 should come up with 2:1, but it comes up with 10 when I press =.
Sep 13, 2009 | Casio FX-300MS Calculator
Is it a bad idea to fly with my akai mpc 2000?
Good idea to carry it with you. Fluctuating barometric pressure will not affect it.
May 27, 2009 | Akai Mpc1000 Music Production Center
Trouble with tribot Mindstorms
posibly missbuilt or miss programed
Dec 03, 2008 | Lego Media Lego Mindstorms
Toys Logo
50 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
