Question about Hotpoint Dryers
Our electric hotpoint dryer stopped spining & got hot & it smelled hot now we can't even get it to turn on
  • 433 Answers
Let's start with the easy stuff.
Check the belt
Thermal fuses
door switch
Do you know where they are?
Posted on Dec 13, 2012
  • 1314 Answers
SOURCE: HotPoint Elec dryer heats up but doesn't dry
yes you have a vent restriction something is blocking your airflow it needs to be an open 4 inches all the way and clear describe your vent to me are you using plastic behind the dryer is it short or all mashed up don't move the dryer get a flashlight and look over the back like its sitting and describe your vent to me from the dryer to the out side if its plastic and looks like a python then you may have found your promblem
Posted on Mar 31, 2008
  • 2692 Answers
SOURCE: DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Posted on Jan 07, 2009
  • 63 Answers
SOURCE: Kenmore 70 series electric dryer. Clothes are
most common reason for this would be clogged vent...check all the way in and out!
Posted on Mar 16, 2009
computer dav
  • 3 Answers
SOURCE: Drye squeaks louldly and smells hot drum stops turning
you have a drum ball that is chrome looking that fails a lot
you need to get the kit and direction from a parts house to fix it ..
mine breakes about every 6 mo
5 boys in the house
Posted on Jun 08, 2009
jumptrout51
  • 3361 Answers
SOURCE: Hotpoint Electric Dryer Model NBXR453EVOWW squealing when turned
Replace the drum support bearing at the rear of the drum.
Posted on Jun 11, 2009
Hotpoint dryer will not heat - cold air only also the dryer will not stop running unless on no heat setting
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'';;
Sep 08, 2011 | Hotpoint Dryers
The coils in back turn red hot and smells like it is burning
Here is a tip that I wrote about why an electricdryer will not stop heating sometimes.
ElectricDryer won't stop heating
heatman101
Aug 15, 2011 | Frigidaire FER311FS Electric Dryer
Hotpoint Dryer has burning smell, checked vent--ok,checked screen just inside--ok. Drum turns. Four screws on back with depression space are extremely hot.
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Jun 27, 2011 | Hotpoint TDC32 Electric Dryer
Hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
May 08, 2011 | Hotpoint Dryers
My hotpoint dryer has. stopped spining everything rlse is ok please help model TLS61p
Do you hear the motor running? If so then it is probably just the belt that has broken...if there is no motor spinning, then the motor may have become defective or the start capacitor may be bad causing the motor to not start
Mar 03, 2011 | Zanussi TC7102W Electric Dryer
My dryer is blowing hot air but the drum is not spining
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Hotpoint Dryers
Hotpoint dryer stop working
if its the same as my dryer CTD40 (or similar) then you have to remove the sides to check into the dryer if anything is stuck, i had a plastic burning smell once and found it was one of the runner wheels had dislodged and was scraping on the drum just re-aline the wheel if it is that, they do come off easily if the dryer has been moved, as i found out. also you will find that the sound of the dryer will change, (scrapeing noise) dont let an engineer lie to you and tell you the bearings have gone, (when i say engineer i mean when you call one out NOT Fixit engineers)
Good luck
Mar 22, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC 30P
Ask your husband to open the service panel and to touch the motor boady when the washer will stop spining. If it is very hot,the problem is with the motor. Before moving to the next step he should unplugged the power cable ! He should then to pull out the motor's brushes (2 carbon units that transfered the current to the motor's armature) and check their condition. If they are in a bad condition they should be replaced. Let me know if you will need for further assistance. Good luck!
Sep 09, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
93 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
