Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Bissel shampooer I have a bissell shampooer powersteamer power brush model 1694-W. I cant get it to dispense water onto the carpet anymore. I think it's because I let my 3 year old ride on it while I was shampooing. I assume I have depressed some special little part that is now broken or mashed or something. Stupid I know....
  • Anonymous Jan 21, 2009
    do i have a belt on this machine to change
Yes there is a belt on the side that will need to be changed
Posted on Feb 17, 2009
My Bissell carpet shampooer will not dispense water or cleaning solution, nor is the "flow indicator" spinning
most of the Bissell carpet cleaners that have the water heating feature stop pumping water at one time or another. Make sure the belt is still on the pump and if it is then the problem is probably in the heater core in the handle. Hard water deposits plug the tiny little water ways inside the heater core. Pull the heater core and take it apart and clean it with a strong scrub brush and I think vinegar works for cleaning I was told. I just use soap and a brush. Then flush all your lines with hot water. The cause is from hard water deposits or leaving the soap in the cleaner after you use it. Both will stop it from pumping water
Apr 29, 2014 | Bissell 1698-1 PowerSteamer ProHeat Plus...
My bissell shampooer 1694 model brushes will not rotate
mine rotates but not smooth...as the part on one side of the roller brush seems to be broken
Sep 28, 2011 | Bissell Powersteamer 1694 Upright Vacuum
Is there any reason the water won't come out?
You need to replace the pump belt, that is why the water is not dispensing and you need to replace the brush belt, that is why the brush isn't spinning. Here are the belts you need.
Bissell Powersteamer Belts
Feb 04, 2010 | Bissell Powersteamer 1694 Upright Vacuum
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell power washer 1694 shampooer
First off is the gasket on the bottom of the tank vavle or sitting in the hole. It has to be on the bucket. May have a problem with the handle not pushing the valve (in the handle)open when you squeeze the trigger. Check the back end of the top cover to make sure it hasn't broken loose from the base, if it has, that raises the top so water won't dispense from the tank. The draw back is that Bissell has obsoleted some parts for this model.
Sep 20, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Powersteamer powerbrush
Brand new out of the box and the bucket didnt fit flush and the shampoo or water not spraying?
Mine was the same lift up the bucket and look at the rubber washer / seal take it off turn it inside out and put it back on.
Wahoo the busket fits the was washes , you have your carpet cleaner back
Jun 26, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Carpet shampooer
I couldn't find the exact guide for your model but the two links below are the ones bissell told me to use. http://www.bissell.com/images/UserGuides/1694-8806_607.pdf http://www.bissell.com/images/UserGuides/1697_1205.pdf I hope this helps:)
Jul 15, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
467 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
