Question about Tools & Hardware - Others
Setting blades on a frejoth planer - Tools & Hardware - Others
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: FITTING DETAILS FOR MAKITA PLANER BLADES
It depends on the planer blade set that you are using. If you are using the the 2 sided blades there is a guage that goes with it to set the blade depth before installing. I would strongly recommend that you go to Makitatools.com and type in your model number and download a copy of the owners manual for specific instructions. Let me know if you have any problems finding them
Posted on Mar 09, 2009
rowdy45176
  • 2176 Answers
SOURCE: how to change blades in planer
Go to Dewaltservicenet.com and type in your model number in the middle of the page at the bottom. Select the model number I looked at a type 2 and click on it on the next page find instruction manual on the left hand side and I did have to click 2 times before it brought it up but it is there I just read part of it. The manual is about 17 pages long but the page you need is 11. Let me know if there are any problems please and if I have helped in anyway would you please rate the response accordingly.
Posted on May 16, 2009
  • 302 Answers
SOURCE: how to replace planer blades to perfection
My planer came with a setting gage to do this job with. Maybe you need to check with the company about getting one of them
Posted on Aug 26, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need instructions on how to replace a new set of
find your model number and go to "makitause.com" and you can download the operators manual with detailed instructions for this repair. REMEMBER to unplug tool before starting. If you give me the model number I will help but they had 2 different types of holders on the planers so I can't begin to help. Let me know.
Posted on Apr 16, 2011
How do I set planer blades on a craftsman bench planer
I usually rest a straight edge, flat hardwood across the drum.
Rotate the drum by hand/pencil tip, till the blade is top dead center..
It should lift the hardwood 1mm.
Tighten the fixings.
Rotate and repeat for remaining blades.
Dec 13, 2014 | Crafts & Hobbies
How do you set up planer blades
Planer blades are set in the cutter head, they must be set at the same height and level. The feed table is lowered to set the depth of cut and the output tabled is adjusted to support the work peice after it passes over the blades
Aug 29, 2014 | Crafts & Hobbies
The roller for the planer blade is stuck
Turn Off the device.
>> Remove the blade and set for correct hight and place.
Mar 29, 2014 | Bosch 3365 5amp Planer
Wood planer
Unplug the machine and readjust the blade setting to sit just past the blade support
Apr 13, 2013 | Tools & Hardware - Others
I own a Sears Power Planer Model 315.17320. Last week I bought new blades, part no. 17326. To install these blades correctly, I need a Blade Adjustment Plate - P/N 1-606871-01. I have been unsuccessful...
It seems that sears has dropped most of the parts for your planer. I can tell you in 2 minutes. Raise the front of the planer up as far as it will go to get it out of the way, Put the planer in a vise by the handle, take a straight edge, like a rule, or square, Put it on the flat rear of the planer bottom, bring the cutter around with a new knife set in there loose but snug, adjust your leveling screw so that the knife just scrapes the straight edge, doesn't pick it up and doesn't pull it, but scrapes it. do the left side, right side, go back to the left, then tighten it up. It is very important that both knives are set the same, so do the other side that same way. Make sure they are all tightened up. Don't answer the phone, You should be all set, hope this helps.
May 24, 2010 | Garden
How to fit bosch PHO 15-82 planer blades
  1. Unplug from mains and turn planer upside down.
  2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
  3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
  4. Rake any dirt out of the blade track with screwdriver blade.
  5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
  6. Repeat with second blade.
  7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
  8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
Pictures below from Bosch manual for further information
Sep 16, 2009 | Bosch Tools & Hardware - Others
How to replace planer blades to perfection
Aug 25, 2009 | Tools & Hardware - Others
Mar 08, 2009 | Makita Planer Replacement Blade, 3 1/4"
Tools & Hardware - Others Logo
114 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
