Question about Kenmore Side by Side Refrigerator
Ice maker won't fill with water
We had unplugged the refrigerator for a couple days because we were replacing it with a new one. We believe it could have been plugged in without the water line being hooked up, but with the ice maker still running. It was on for about a day like that. The we had it unplugged for about 3 days, when we plugged it back in it shorted out 3 times and it was black up around the ice maker. Everything still works except the water won't fill the cube treys.
  • Kenmore Master
  • 8,220 Answers
Well the ice maker itself is what calls for water. It probably is fried. The way it works is the ice maker basically sits in the freezer and waits until the ice mold reaches 28f. When it gets to 28f the ice mold thermostat closes the electrical circuit to the heater and the motor. The motor basically stalls out because the heater hogs all the power. As the ice loosens the motor does not need as much power and manages to move the ice till you hear a CLICK and that is what kills the power to the heater and the resulting surge moves the ice on around at an astounding snail pace not unlike watching grass grow. At near the end the water valve gets energized by a probe rubbing against a copper plate located behind the main drive gear. over time it gets to where the arcing sticks the probe to the plate and instyead of 7 seconds of fill time it fills for 25 or more seconds or just smokes up the puppy and burns the tip of the probe.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 12, 2012
fridgetech
  • 473 Answers
SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this.  Let's solve it before you rate it.
Posted on Oct 18, 2007
  • 25 Answers
SOURCE: adjusta ice cube maker not working
Have you checked if water is comming out the tubing before hookup? A valve may be close...
Posted on Dec 10, 2007
aborcass
  • 2651 Answers
SOURCE: water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Posted on Feb 23, 2008
huuum
  • 750 Answers
SOURCE: ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Posted on Oct 12, 2008
  • 3 Answers
SOURCE: Brand new Kenmore refrigerator, ice maker does not work
According to the manufacture, you must wait 24hrs to reap the benefits of the automatic ice maker. I was helping a friend the other day install a water line to a side by side unit that had been running for well over a week and after turning the water on we got no ice. We contacted the manufacture and they said "there is a 24hr waiting period". This makes no sense. I wasn't trying to get a gun permit, just ice.
Posted on Jan 13, 2009
Water dispensing into ice maker won't shut off
There should be a float or electronic water level sensor that will tell the water to shut off, if it has calcium from the water on it or the float is damaged it will keep sending water until manually shut off(pull the plug). I would look for a water level sensor of some sort and clean or replace it. If that doesn't work it could be a sticking water fill solonoid which you should then replace
Sep 06, 2012 | General Electric GSH22JSXSS Stainless...
Tfx20r ice maker won't fill
Try this fill the ice maker with tap water so we can decide if it is the ice maker or the water control valve. After the water freezes if the ice dumps and the ice maker does not refill with water then you will need to replace the=> WR57X10033 Water Control Valve If the ice maker does nothing after being filled with tap water and the water freezes then this would point to the=> WR30X10093 Ice Maker Assembly If you have questions I will be here to answer them for you, Thanks, Sea Breeze
Jul 06, 2012 | Refrigerators
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
Ice maker is not working. doesn't appear that it's
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Have a good day : )
Sep 03, 2011 | Kenmore Side by Side Refrigerator
Ice maker will not make ice Model number
  • When it Won't Make Ice
    • 1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
    • 2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
    • 3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
    • 4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
  • Hope this tips will help you.
    Have a nice day! : )
    Aug 28, 2011 | Kenmore Refrigerators
    The refrigerator and freezer works fine. The problem is it is leaking water from somewhere under the frige. The condensor was cleaned out this last week and did have a lot of dust. Couldn't find any...
    When the Ice Maker Leaks
    1 Refer to your user manual to determine where your fill volume adjustment dial, is and turn it down. One-half to one full turn usually is approximately equal to 20 to 40 cc, and the correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
    2 See if there are icicles hanging from the fill spout and/or on the ice maker's sides. If there are, this means your water inlet valve is leaking and will need replacing. Refer to your user manual for a part number, or call a technician.
    3 Check to see if the ejector seal is cracked. If it is, replace it. Refer to your user manual for a part number, or call a technician.
    When the Ice Smells
    1 Replace water filters every 6 months to avoid musty odors from getting into your ice. If you don't replace the filters, they become clogged with the chemicals they have been removing from the water. In addition to smelly ice, you may see a drop in water pressure if you have a water dispenser, and possibly a decrease in ice cube size.
    2 Remove the cap from the new filter.
    3 Place the cartridge inside the holder, and twist to the right.
    When the Ice Maker Produces Hollow Ice
    1 Replace the fill and shut-off valve for problems with both parts. Hollow ice cubes usually indicate a low water problem. This is generally the result of an excess buildup of calcium and other deposits.
    2 Replace the self-piercing shut-off valve with a drill-type shut-off valve.
    3 Drill a 1/4-inch hole into the pipe and install the shut-off valve the same way you would have installed the self-piercing valve
    Some are tips for your future reference.
    Have a nice day!
    Jun 01, 2011 | Refrigerators
    My ice maker in my freezer calls for water and water flows for about 20 seconds and overfills the tray and then water runs down in the ice bin and down inside the freezer. It is a Kenmore SXS from 2000....
    1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
    2. Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
    4. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
    1. Refer to your user manual to determine where your fill volume adjustment dial, is and turn it down. One-half to one full turn usually is approximately equal to 20 to 40 cc, and the correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
    2. See if there are icicles hanging from the fill spout and/or on the ice maker's sides. If there are, this means your water inlet valve is leaking and will need replacing. Refer to your user manual for a part number, or call a technician.
    3. Check to see if the ejector seal is cracked. If it is, replace it. Refer to your user manual for a part number, or call a technician.
    Hope this would help you.
    Have a good day : )
    Apr 08, 2011 | Kenmore Refrigerators
    Leaking water in icemaker. water from icemaker leaks into freezer and freezes on freezer wall
    If you are sure that it's coming from the ice maker I believe that you possibly have a leaking water control valve on the side for the ice maker on the rear of refrigerator near floor there is a dual water valve control. Many times when this happens the water will freeze in the fill tube that fills the ice maker in the rear of freezer. You can defrost the frozen water in the fill tube with a hair dryer but that will not stop the problem from coming back. When that happens water tends to at times go everywhere but the ice maker. You can test the water control valve several ways. By unplugging the side to the ice maker and if water continues to flow slowly to the ice maker then the dual water control valve will need replaced, Sea Breeze
    Sep 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Brand new ice maker, water fill to tray will not shut off
    The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
    Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
    Kenmore Side by Side Refrigerator Logo
    65 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    ka4iup
    ka4iup
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
