Question about Sharp AL-1641CS All-In-One Laser Printer
The printer is making a banging sound and won't print
There is a part that is located toward across the back of the machine when the top is up. Its a thin almost chain like part that is moving and banging.
    Problem Solver:
  • 14 Answers
It sounds like the timing is out, or one component on your optical section has gone out of its timing sequence. However i have had some units on the main drive section that has given the same symptoms. Its best to inspect all drive gears at the same time
Posted on Jan 08, 2013
Replace printer head with brand new one sent to me by lexmark. when i press copy the print slides to the opposite end and starts banging at the end of printer then i get error massage printer head can not...
Make sure that there's nothing blocking the path of the printhead. Check inside the printer for any foreign objects.
If there's none, please contact our technical support team to have the printer replaced.
Also, try to unplug the power of the printer for about 30 seconds then plug it back in.
Nov 06, 2012 | Lexmark 90T3005 - Impact S305 Wireless...
Printer is paused all the time
Hello, sounds like your drivers are messed up, reload them to the computer or the connection cable maybe bad. If neither of these fix then the printer is bad.
Sep 05, 2012 | Canon PIXMA MX870 Wireless Office...
Machine is making an extremely loud banging sound think the blocks come loose. How do I fix this what will I need ?
your washer is off balance the inside of the washer is banging the outside wall you can pull it towards the back of the machine and it should slide back into place...
Nov 10, 2011 | Samsung Washing Machines
Installed new ink on ip4200. Black will not print on test page "horizontal box", other colors print. Any suggestion on why the black won't print? Thanks.
The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (A), it is properly removed.
  3. If the orange tape is as shown in Figure (B), remove the remaining tape to the level shown in Figure (A).
  4. Make sure each ink tank is snapped into the printer.
Aug 26, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
Cartridge banging on the right & left walls
There is a thin plastic strip that has small lines on it that stretches across the inside of the printer and fits trough the back of the print head. It is not in the slot of the print head or missing. I fixed my banging Dell 810 printer by putting it back in. I had no idea what it was at first. That's all I can tell ya.
Feb 03, 2009 | Dell 810 All-In-One InkJet Printer
A loud banging noise from inside - as it adjusts post printing
I'd check that there's nothing that's fallen into the rear paper feed that is now causing the rollers to jam and release with the bang you mention.
If you're feeling brave I'd try holding the printer upside down (get a friend to help you and watch out for the scanner sliding out!) and give it a bit of a shake to see if anything drops out.
Jan 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Fuser
this is a too complicated if you a not a serviceman
Feb 04, 2008 | OKI C5100n Laser Printer
Sharp AL-1641CS All-In-One Laser Printer Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
