Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
The channel search wont pick up any channels nor will the channel update but they work on my other TVs
    Top Expert:
  • GE Master
  • 14,553 Answers
You may have a bad tuner in this set, if the rear audio/video inputs work with a DVD etc you can get a cable box and connect to a rear input and bypass the entire problem.
Posted on Dec 13, 2012
Why will my new tv not pick up any channels when using the auto channel search
It depends on if you have cable or are using an antenna. If you have cable, make sure you have the cable that runs in between them hooked up to the correct spots. If you're using an antenna, you might need to get a TV converter box. A couple of years ago, they stopped making regular TV channels and switched to only digital channels. Most older TVs don't work with digital channels, so you need a box that will convert the picture. You can get one at any place that sells TVs (walmart, amazon, etc)
Feb 02, 2015 | Televison & Video
Does not pick up standard channels for recording let alone digital channels
Are you trying to pick up standard analog channels (the kinds that have a fuzzy gray screen when there's no signal)? Those stopped functioning in 2009 when the nation ended the analog broadcast. You can only get digital channels now, except for a low-power broadcast station here and there. Nowadays for analog, TVs mostly pick up only radio stations.
Jan 29, 2018 | LG Televison & Video
Philips led t.v 4000 series 29pfl4908 saying error wont change channels
If you want to get details about software update, check this site. Pull up previous posts there. Software update to many model and brand TVs are given in detail. Check the site with patience. Check the site by 'Timeslide' option, which can be selected from the drop-down box at the top left part of display window. It will make search easy.
Mar 31, 2013 | Philips Televison & Video
I have lost Sky Channel 82 from Freeview on Samsung HD TV I have tried to reinstall but channel 82 is still missing
U have more than one tv?Yes.Tries check on the other tvs see if u have channel 82 freeview channel,freeview channels are take out or add on all the times by the tvs stantions broadcasting listing.If yes channel 82 is on the other tvs.Than u have low or weak antena signal.U have a analoge antena probally correct?Buy and install a digital antena,u will get a stronger longer ranges tvs incomming broadcasting chaanels tvs stations.Rescan for channels again,u will pick up channel 82 if it still on the air.
Aug 11, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
LG LCD TV 37LP1D digital freeview tuning problems
Hi - I have the same problem. Also in Cornwall LG were not interested in helping because the TV was 3 1/2 years old. There was a possible fix in the end offered via LG at a cost of £180 + vat - a hardware update that might or might not work but I was not going to pay that so I now watch my LG 42 plasma via a £25 digi box from the CO OP. LG must have sold 1000's of these Tv's so when the digital switch starts in the more populated areas of the country I exect many more web postings.
Oct 31, 2009 | Televison & Video
Unable to pick up local ''free'' channels following digital change over. Using RCA DTA800 converter and Phillips 2750/27 antenna. Can pick up only one local channel, but signal loss is more often the...
first of all, make sure all your connections are secure and threaded all the way in. Next, go to the main menu and press 5 (configuration) and press 1 (search for channels) if this doesn't work, press 4(signal strength meter) and see how strong your signal is. You may just need to re-position your antennae. If all else fails try system reset(number 5) and repeat search for channels. I've had similiar experiences with mine but I have a 62% signal strength and still get 20-something channels. Hope this helps.
Oct 11, 2009 | Televison & Video
How to update digital channels correctly
the information I needed was in the FAQ's area. Thanks
Jun 05, 2009 | Sansui 19 in. LCD TV
UNABLE TO VIEW ITV CHANNEL 4 OR SKY SPORTS NEWS ON MATSUI TV
try tuning tv in another room, if it works it is then your cable or socket, try the cable next. If it wont tune its a faulty set.
May 26, 2009 | One For All URC-3445 Remote Control
Tuning in the tv
Most TV's auto search feature will try both the Cable and the Air frequencies, but perhaps yours doesn't. Go to the menu page for tuner setup and make sure it is set on Air (might be called broadcast) and then run the channel search.
Cable channels and Broadcast channels (above channel 12) are not the same frequencies.
Hope Ya Fix It!
Jan 10, 2008 | Televison & Video
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
