Question about LG RU-42PX11 42 in. EDTV-Ready Plasma Television
50/50 split in screen no picture on bottom half
I bought this TV not working, I thought I could learn a bit by trying to fix it. I replaced a couple of boards and I can get it to display the top half of the picture but I don't want to spend any more money fixing it, I already spent too much. Just trying to recoup my losses a bit by selling it (also can't bear to throw an almost working tv out)
Sony trinitron tv
Hello!I bought 12 years ago a SONY TV KV-28FX60D with out any technical issue so far.The last couple of days I powered on and after five minutes it starts showing only half of the screen, losing the bottom half of the picture. what do you think it might be. Can you suggest a part to be replaced and if it is worth fixing, cost wise? Thanks KONSTANTINOS
Jan 02, 2014 | Televison & Video
LG 50" plasma has sound but no picture
It sounds that you are something in electronics, and can understand the things well. Check the site liked below.
May 20, 2013 | LG 50PG20 50 in. Plasma HDTV
When you turn the TV on the screen splits in two,
it sounds like one of your buffer boards are going bad. these are the boards that help put the picture on the screen. there are 2 boards an upper and a lower board. if you remove one and turn the tv on you will get half a screen. see then if you get the lines. please leave rating after you check.
May 10, 2010 | Hitachi P50H401 50 in. Plasma HDTV
SPLIT SCREEN ON 50'' PLASMA
If you talking about on one screen, you cant. BUT you can buy a TV card for your computer so that it will have a built in TV. so you can theoretically have split screen TV and computer. But what your thinking off only works on 2 or more player games consoles
May 04, 2009 | Samsung PS50A457 50 in. Plasma TV
Panasonic TH-42PX60U PLasma - 1/2 screen blacked out
If the screen split is exactly 50/50 top/bottom You are not getting SU or Scan Upper drive.
These are lovely set to work on.
Most likely is SU board itself - Not repairable just to be replaced.
Sorry I work in the UK so I can only guide that the UK part is around £30
SU may have been damaged by failure if the PDP (Plasma Display Panel) but is 9 years only had 2 screens damage the SU board.
There are several setups to do after fitting a PDP. If you don't have the service data - Do not risk it, Reduced life of the Panel and a safety risk.
Jul 21, 2008 | Panasonic TH-42PX60U Television
White line
you have a shifted picture upwards the white line is the overlaped picture. Try accessingthe service menu and shift the picture down. Patrick
Jun 18, 2007 | Daewoo DSC-30W60N 30" TV
Split screen from DVD player, cable is fine no problem
It is not clear where you say input is from cable, do you mean the Scart input to your Sony TV? Do not use Progressive scan(p), as this is not interlaced. The normal TV requires an interlaced(i) picture of 50 half frames per second giving 25 complete pictures per second to reduce flicker. Some TVs and projectors and all monitors accept Progressive scan.
Oct 15, 2006 | Sony KV-32S25 32" TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
LG RU-42PX11 42 in. EDTV-Ready Plasma Television Logo
61 people viewed this question
Computer Repairing
Computer Repairing
