Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Car alarm goes off after starting car remotely
  • Viper Master
  • 625 Answers
It's possible that that could be the shock sensor. Adjust it downward or, bypass the sesor prior to remote starting the vehicle.
Posted on Dec 16, 2012
4 Suggested Answers
  • 12 Answers
SOURCE: problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Posted on Jan 15, 2009
insanegtp
  • 112 Answers
SOURCE: I have a viper 5900 car alarm installed with remote start.
Look under dash for a small black box with wires coming out of it, about 2 or 3 inches rectangular.. there should be one or two screws on it. Look to see if it says which direction to turn for sensitivity. As far as not receiving, you need a new antenna, this is covered under warranty through DEI either bring back to where you purchased or look online and see where the closest dealer is to you...
Posted on Jan 29, 2009
  • 132 Answers
SOURCE: Lost my remote viper remote
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Posted on Oct 15, 2011
My alarm goes off when i try 2 use my remote start for my 2006 malibu lt v6
To remote start: Press Lock briefly and then hold down arrow key. (Remote start button is key that looks like an arrow going in a circle) Any other combination can set off alarm or panic feature.
Dec 02, 2013 | 2006 Chevrolet Malibu
2005 sedona alarm
Please be more specific. Is it the factory alarm going off when you remote start or, is it the Viper alarm going off when you start the car with the key?
Jan 24, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
When use remote starter to start car, factory alarm goes off. How can I use the remote starter without this happening?
It sounds as if your vehicle's factory alarm is not disarming before the remote start sequence. You will have to disarm the factory alarm before start. On most vehicles there is a disarm wire, usually in the door that operates with the key cylinder. To test, probe the wire at the key cylinder while unlocking the door with the key. Some vehicles have the disarm wire in the driver's kick panel, but they operate the same way (with the key cylinder). Other vehicles can be disarmed with pulsing the key sense wire. Some vehicles do not have a factory alarm disarm wire,i.e. some Subaru and GM cars and trucks. They can only be disarmed through data modules. More information on the year/make/model of your vehicle will be needed to accurately solve your problem.
Nov 08, 2010 | Prestige Remote Start
Keyless remote is not working & alarm goes off & won's turn off
before doing anything... use the key to unlock the door...then the alarm will not go off
Jul 20, 2010 | 2008 Nissan Sentra
Alarm goes off when trying to remote start my o 06 malibu was up!!!
i hav same problem chaged battery noticed battery holder was loose so i soldered it very carefully everything works fine xcept remote start alarm just goes off like when you push the panic button not sure what happened dont think i shorted out the circuit board in the fob if engine light is on this car wont start via remote these remotes must b progamed by dealer or pro shop prob using what they call a tech II computer to remote start you hav to press lock button 1st even if car is already locked i figured this out pess and hold lock button then press start alarm dont ring and the car starts.
Jan 13, 2010 | 2005 Chevrolet Malibu
Alarm goes off when new battery in placed in car, when alarm finally goes off and we try to start the car the alarm goes off again and the car won't start. I do not have a key chain with an alarm...
Hello. If you have a FACTORY alarm system, the deactivte prodedure is to cycle the key off-on (not to start) 5 times, in the ignition. This feature is provided in case you lose the remote, or the remote battery goes dead.
Note: this will only work with the Factory system. If you have an aftermarket system, this answer will no benefit you.
Dec 12, 2009 | 2001 Toyota Sienna
2005 Grand Prix remote start causes alarm to sound.
remote start systems have a dis-arm alarm output wire ... this must be connected to the OEM alarm disarm wire ... your installer needs to service it.
May 08, 2009 | OEM Systems Vehicle Parts & Accessories
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
77 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
