Question about Hardware & Accessories
I have three plug timer, can't get it to program
Cannot get it set to come on and go off when i want
  • 5,245 Answers
1) Timer is unknown.
Look at timer photos on following page to help identify timer, and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
2) Add comment and describe timer in detail ... after opening links above to narrow down search, and then say where the instructions are confusing.
3) Dec 2012. I will respond to comment posted if fixya sends me linked email per usual, most of the time.
Posted on Dec 13, 2012
I am looking for timer instructions for a Defiant brand outdoor heavy duty digital timer. Has option for three plugs at the bottom. I do not know model number. I can't figure out these "modes"!!!
a mode is a operation program in the computer
for example mode 1 is timer time
mode 2 is set adjusted time
mode 3 no of sprinklers on mode 4 set
mode 5 etc
the mode is used to move from one program to another and once a change is made in that setting the mode button then saves that setting
all of this would be explained in the operators manual
Oct 24, 2016 | Heavy Duty Hardware & Accessories
Noma 052-8870-6
OUTDOOR DIGITAL BLOCK HEATER TIMER 052-8835-2 Instructions Plug timer into grounded outlet
To Set the Current Time: Press the HOUR button as many times as necessary to advance the display the correct time. Note, the time can only be set in 30 minute intervals. The LED display will display the hour (1-12) and on the half hour a light will illuminate in the upper right corner, next to the number 30. To change from AM to PM toggle 24 times, a dot will illuminate in the lower right corner of the display next to the letters PM.
To Program the Timer: Press the PROGRAM button once, the letter P will flash. Press the HOUR button to set the ON time. Press the HOUR button to set the ON time. Press the PROGRAM button again, the letter E will flash. Press the HOUR button to set the OFF time. Press the PROGRAM button to exit program setting mode. Press the HOUR button to review the ON/OFF setting.
To Connect/Operate the Timer: Plug device in to the timer and turn the device on.
To Revise the ON/OFF Setting: Unplug the timer and plug it back in. Repeat the programming steps above.
To Override the Timer: Press the PROGRAM button if you want the device to turn on before the preset time, but note the device will turn off at the preset time. For example, if the preset ON/OFF period is 3 pm - 4 pm, users can manually press PROGRAM to turn the device on at 2 PM, the timer will keep running until the preset off time at 4 pm.
Suitable for use with outdoor appliances. Raintight when mounted vertically with the receptacle facing downward. Use a three-conductor GFCI protected outlet. Do not immerse in water. DO NOT EXCEED RATED CAPACITY. Not for permanent installation. Do not install or use this product for more than a 90-day period per year.
Dec 02, 2013 | Hardware & Accessories
Timer is programed & is currently in off state but my stuff is still on
Specifically which timer do you have??
1) Reset timer to Clear programming, and then reprogram being careful to avoid overlaps and conflicts that can cause timer not operate as expected.
2) Move timer to different outlet.
3) Test outlet with circuit analyzer
4) Try plugging different load into timer. For example a light bulb instead of pump.
5) Check rating plate on timer and on pump to see if they are compatible.
For example Sylvania SA-210 outdoor timer is rated for 1/4 Hp at 120Volts
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
While Intermatic P1261 timer is rated for 2 Hp at 120volts
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#outdoor
Jul 17, 2012 | Sylvania SA210 15 Amp Zip-Set Digital...
Garrison RCT100 DIGITAL TIMER
Yes.
Timers usually don't last more than a few years, unless you buy the heavier duty box timers that last decades.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Dec 20, 2011 | Hardware & Accessories
How do we clear out the timer settings
Timer is not identified.
Open following link to identify timer and download manual.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
1) If you have zilla digital power strip, there is no reset button.
It appears you can reset timer by removing small battery located on back of timer.
Battery serves as a back-up for timer settings, and display will not show without battery.
Most battery-operated timers that do not have reset button are reset by removing battery.
Some battery operated timers retain programming forever even if battery is removed for months, and then programming is still there when new battery is installed. However this type of timer has a reset button, but zilla does not.
2) A second way to clear programming is to press PRG button to review each program, and set each program to another time. I don't know if this will work since you can't 'zero' out the settings.
Jul 30, 2011 | Coralife Power Center DayNight Timer or...
I put the timer on my lamp and it stays on even if it's not the time that I set, and then it turns off when the time is up... Why does it stay on? And not go according to the timer?
For digital timer:
1) Timer is defective
2) Conflicting programming so timer does not perform as expected
3) Timer not set to correct mode.
4) Program 'off' is set correctly, but program 'on' is not set or 'on' time conflicts with other programming.
5) Current time not set correctly
6) Polarity on outlet is reversed or noise on the line. Check outlet with circuit analyzer.
7) Combination of factors listed above
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
Jun 26, 2011 | Woods Indoor 24 Hour Digital Timer (59203)
How do I turn off the delay timer? When I set it up, the timer automatically sets it on a 3 hour delay. I have moved the up & down arrows but it won't set at 00:00 unless I unplug it. Then I set...
No offense intended but you need to step away and read the instruction manual step-by-step. One point I can make: The three hours you're seeing in the display when you first plug the unit in are simply telling you how long the default white bread mode is going to take to complete. It's merely a counter that counts down so at any time you glance over at the machine you'll know how much longer it's going to be before the bread is finished. The digital display has NOTHING to do with the delay timer until you start pressing delay timer arrows.
Hope this helps!
Jun 20, 2011 | Breadman TR777C Bread Maker
Hey i;m hector : MY PROBLEM / 7 DAYS SETUP NO WORK ; ( ej: TIME ON 8.00PM- TIME OFF 5.00AM( SEME DAYS MONDAY TO SUNDAYS?
Hi Hector.
You posted under ET171C8.
You have the timer in front of you, and whole manual cannot be repeated. So there are two options
1) Free option: Add a comment and say specifically where the programming is tricky. If you don't understand the buttons, or if display doesn't show, or if you can't find all days by pushing day button, or if you can't find the am pm choice.
2) Pay for fixya expert to walk you through each step via e-mail.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et171c%20-%20english.ashx
http://www.intermatic.com/products/timers/electronic%20time%20switches/7%20day%2030%20amp.aspx
If display shows, then battery is correctly installed.
Instructions copied from manual:
1) RESET TIME SWITCH: Press the recessed RESET switch to reset the
microprocessor and delete any set point information which has been
programmed. NOTE: DO NOT press RESET after programming has
begun or you will lose all of your program information.
2) TO SET TIME AND DAY OF WEEK: Place the three position selector
in PROGRAM and the two position selector in CLK mode. Press the
HOUR, MINUTE and DAY buttons individually to select the current time
of day (12 hour AM/PM repeating) and the day of the week. Day 1 is
Sunday, day 2 is Monday, etc.
3) TO PROGRAM SET POINTS: Select PROGRAM mode with the three
position selector and OUTPUT mode with the two position selector.
Press the HOUR and MINUTE buttons separately to program the first set point time desired.
Press the DAY button to select the day the event is to occur.
Press the ON/OFF button to select an ON or OFF set point.
Press the ENTER button to enter that set point for the selected day.
Note that the ON or OFF indicator stops flashing only after pressing ENTER. If this set point is to occur for other days of the week, simply press the DAY button to select the next day then ENTER. Repeat for any additional days. Note that this allows you to utilize one set point for
any or all days of the week.
Then set timer to AUTO for programs to operate
Apr 26, 2011 | Intermatic ET171C8 Electronic Timer
Lost instructions for TE109 appliance timex timer.\r\nCan you help? Thank You & Merry Christmas
    • Plug your Timex seven day timer into a standard electrical outlet. Allow the timer's rechargeable battery to charge for at least 10 minutes before attempting to program the appliance; the battery will serve as a backup power source to prevent your custom programmed settings from being lost in the event the timer is unplugged or the power goes out.
    • Press the depressed "RST" button on the timer with the tip of a ballpoint pen to reset the timer's internal memory.
  • To Set the time on your Timex timer. Press and hold the "Set" button for three seconds or until the day-of-week indicator begins to flash. Press the "->" or "<-" button repeatedly until the desired day appears on the digital display; press "Set." Use the "->" or "<-" buttons to set the hours when they begin to flash; press "Set" when the desired hour is shown. Use the same process to set the minutes, then press the "Set" button again to confirm the day and time settings.
    • To Program a start time for your seven day timer. Press the ">" button to access the appliance's programming mode; the program number will begin to flash. Use the "->" and "<-" buttons to highlight the desired program number, then press "Set." Highlight the desired day and press "Set" again. Program the hour for your timer; press "Set." Set the minute and press the "Set" button to confirm.
    • wait for the timer to go back to std mode (like 10 seconds)
To program a stop time for your timer. Press the "Set" button to cause the day-of-week indicator to flash. Highlight the desired day and press "Set" to confirm. Adjust the timer's hour with the "->" and <-" buttons; press "Set" when the desired hour is shown. Set the minute for your timer and press the "Set" button again. Press the "Time" button to exit the setting mode.
Dec 17, 2010 | Timex Hardware & Accessories
How to program a intermatic outdoor timer/photo control hb51rc
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
1. Turn dial selector to the "off" position and
plug timer into three conductor outdoor outlet.
2. Turn dial selector to timing interval
desired (i.e., 2 Hrs, 4 Hrs, 6 Hrs, 8 Hrs,
dusk to dawn, etc.).
3. Plug outdoor lights into Easy-Set™ Timer -
lights will turn on automatically at dusk.
4. Lights turn off 2 4 6 or 8 hours later
depending on dial selection
Dec 07, 2010 | Intermatic Outdoor Timer/Photo Control...
Hardware & Accessories Logo
27 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
