Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Olivetti d-35 error code C6050 - Kyocera Mita KM-3035 All-In-One Laser Printer
3 Suggested Answers
  • 36 Answers
SOURCE: Sytem error C6050
This Code means low fixing unit temperature. If the power goes off and on, or Suzy Sec. has a space heater on the same circuit, this could be a false code.
Enter the service mode by keying in the numbers "10871087", on the key pad. enter the number 906, press start, press "execute"on the touch panel. The machine will reboot.
If the code comes back, you either have a bad thermistor, thermostat, or heater lamp. I have only had to replace the thermistor. The Fuser comes in the maint. kit ,so I always have some old ones laying around.
Posted on Jan 18, 2008
mysticus_tam
  • 40 Answers
SOURCE: Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
Posted on Dec 21, 2009
OLIVETTI D-COPIA 1600 ERROR C6050
Plz cod c4000 error d.copia 1600
Aug 07, 2013 | Office Equipment & Supplies
Olivetti d-copia 16w error code H4
I need driver olivetti_d_copia_16w for winXp....
Sep 25, 2012 | Olivetti Office Equipment & Supplies
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Apr 09, 2010 | Copystar CS-1620 Copier
Error Code C6050
May 25, 2009 | Kyocera Mita KM-2050 Printer
Error: Call Service Code: C6050
try to press code 10871087 then 163 and lastly press clear/stop button for a while.
Nov 17, 2008 | Copystar CS-1620 Copier
Ribbon supply
This ribbon fits many different typewriters 25 and 35 are the same. Spool should be the metal type not the plastic, and you need the nuts on the top....
Mar 20, 2008 | Olivetti Lettera 35 L Typewriter
Sytem error C6050
Jan 14, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
212 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
