Will not connect to wireless network,did in the past. Model E552VL
I now have a Belkin Dual band N+ router Model N750 DB
  • 7,627 Answers
4 Suggested Answers
Tom Marvolo
  • 708 Answers
SOURCE: how do i connect my xbox 360 live to my belkin
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Now lets configure
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Scan and connect to this network and test the connection
If working then let me know
Posted on Jan 18, 2011
Geekman
  • 32281 Answers
SOURCE: Belkin N750 DB wireless connection drop
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Posted on Apr 24, 2012
maxcarson
  • 7627 Answers
SOURCE: can't connect vizio smart tv with belkin n750 dual band router
In your TV's menu there should be a wireless setup. You didn't supply the Model of the TV. Here's a manual for a Vizio: http://store.vizio.com/documents/downloads/hdtv/M3D650SV/1185QSG_M3D650SV_B.pdf
Posted on Dec 10, 2012
What modem are compatible for n75 db dual band N router
Any modem should work; the modem is the device that provides a signal to and from the router. I have never run into any compatibility issues for a signal TX/RX device.
May 17, 2014 | Belkin N750 DB Wireless Dual Band N Router
Usb ports do not light up
You are not the only person having problems with the Belkin N750 DB Wireless Dual Band Router. Are you using the correct cables? One more thing you can check, does it have a reset button on the bottom or the side? Try those two things.
Feb 12, 2014 | Belkin N750 DB Wireless Dual Band N Router
Forgot pass key
Reset the Belkin to default settings and reconfigure the SSID and the Security Key. You can find a User/Setup Manual here: http://www.belkin.com/networking/manual/MAN_F9K1103_8820-00778_RevA01_N750.pdf
May 26, 2013 | Belkin N750 DB Wireless Dual Band N Router
Cannot get belkin N750 to reset to fix the lost password
Make sure you hold the reset button on the back of the router for 10 seconds. This will do a factory reset for you, simply hitting the button will only restart your router. Once you're done resetting it, connect to your wireless network using information provided on the bottom of your router box and go to either http://192.168.2.1/ or http://router/ to configure it again.
Apr 23, 2013 | Belkin Components Belkin F9K1103 N750 DB...
Belkin n750 db wireless dual band n+ router setup disc error
You didn't supply the OS you are using, it may be a software compatibility issue. Look for download for your OS. Try Belkin Support : http://www.belkin.com/us/support-product?rnId=6054
Dec 23, 2012 | Belkin N750 DB Wireless Dual Band N Router
Driver needed to download
No drivers are required since routers are not installed but are administered. No disc required, but comes with one if you elect to use.
Connect the ISP modem to main up-link port in router. Then connect PC to any other port. Done!
Wireless is a different setup.
BTW I have same model.
Dec 10, 2012 | Belkin N750 DB Wireless Dual Band N Router
Belkin n750 db connects with windows 7 laptop, but will not connect with xp laptop. It will not let me enter the password.
It is possible that, if you have the router set to wireless N only, your XP machine won't interact with it. Your XP adapter probably doesn't support wireless "N"--you'll have to tell the router to use "N" or "G"
Apr 21, 2012 | Belkin N750 DB Wireless Dual Band N Router
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
