Question about Craftmade International Dryers
Need a manual for allen + roth remote ceiling fan model lp8076
SOURCE: Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Posted on Sep 05, 2007
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
SOURCE: Minka Aire remote controlled ceiling fan
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Posted on Feb 25, 2009
  • 3 Answers
SOURCE: Lost Instructions for Hampton Bay remote control 838956
Go to www.kingoffans.com and follow the site. They are the makers of Hampton Bay.
Posted on May 24, 2009
SOURCE: installaion manual for ceiling fan
there was no manual for my Aloha Breeze 42" ceiling fan with light fixture model number is 49001
Posted on Aug 21, 2009
Allen + roth santa ana ceiling fan manual
What kind of wiring diagram are you looking for? fanman9952@aol.com
Mar 10, 2016 | Dryers
Allen + Roth ceiling fan with remote Model #: LP8242LCH. The light randomly turns on. Not touching remote. Any ideas how to fix it?
Change the frequency in the receiver & transmitter. Also, stay away from store brand fans.
Nov 22, 2014 | Dryers
Allen & Roth Eastview ceiling fan. How do I reverse to pull up warm air instead of blowing air down?
Look for a slide switch on the side of the housing beneath the motor. If the manufacturer wired it correctly, the up position will pull up warm air and the down position will blow air down.
Jan 09, 2014 | Dryers
Trying to install an Allen & Roth Ceiling Fan Model#LP8062 Help it doesnt seeem like the light open to change a bulb and the blades dont come off Help?
That's just a CHEAP store brand fan. Take it back and go to a real fan store and get a fan with at least a 13 degree blade pitch or at least 5500 CFM's
Nov 03, 2013 | Dryers
I have a Allen and Roth double ceiling fan and now the light will not turn off by the pull string, so we can not have the fans on with the light off-- ANY HELP?? Its only a year old ;(
The light switch may have failed. They tend to do that.
You don't say whether your fan has a remote control, but that could be the source of your light problem as well
Jul 09, 2013 | Dryers
Designers Choice Ceiling Fan Manual
All Hunter fan model numbers are 5 digit and start with a 2. Are you having a problem with the fan?
May 16, 2013 | Hunter Designer's Choice 5-Switchblades Lg...
The remote on my Hunter ceiling fan (Model: 27185 - 060) does not activate the ceiling fan. I can turn the light on manually, but not the ceiling fan. I cannot see the antenna on the ceiling fan.
The first thing you need to do, is change the battery(s) in the hand held remote, as well as the battery(s) in the receiver inside the fan's cowling. Weak batteries will limit a remotes operation.
And, FYI - there is no antenna on the ceiling fan.
I hope this helps you. Thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
Need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Apr 24, 2010 | Hunter Ceiling Fan Light Remote Control
I need to install a Hampton Bay ceiling fan Model AC552 but I have no instruction manual. Can I be emailed one.
look into the internet for download of that manual model with the full name of product for instruction manual. try that.
Oct 03, 2009 | Hampton Bay 52 In. White Redington...
Dryers Logo
190 people viewed this question
Top Craftmade International Dryers Experts
Andrew Taylor
Andrew Taylor
Jerry Kramer
Jerry Kramer
Rani wadia
Rani wadia
Are you a Craftmade International Dryer Expert? Answer questions, earn points and help others
