Question about Lexmark E460DW Mono Laser - 38ppm, 466MHz Processor, 1200 x 1200 dpi, 250 sheet input... Printer
Paper jam we have an OEM cartridge but the Machine jambs once in a while
  • Official Brand Answer
  • 3,344 Answers
Please refer to this article: http://bit.ly/UG6ujm, to clear paper jams within the printer.
Posted on Dec 14, 2012
  • Yosi
    Yosi Dec 14, 2012
    Thank you, we'll keep you posted if problems continue, we also changed the PC Yoskke
C5180 jam in carriage - removed paper but not printing
Check at the cartridge end of the machine. I found a piece of paper jambed in that kept the carrige from parking on the right side. I had to turn off printer. take the paper trqy out and turn the machine on it's right side and use a flashlight to find it and get it out.
Dec 31, 2014 | HP PhotoSmart Office Equipment & Supplies
The paper does not feed correctly so that the paper goes into the machine crooked causing a paper jam.
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Aug 27, 2011 | Canon Office Equipment & Supplies
Photo Paper keeps jamming
It's the top rollers, the paper is too slick to get through them. I'm using HP photo paper, in an HP printer. It needs to do a 180, but gets jammed right where it prints, so the paper never makes it to the ink. It's an engineering problem by HP. I suggest putting a rough surface on the top edge of the photo paper, something removable but rough enough for the printer to pull the photo paper through.
Jul 12, 2010 | HP Officejet 6310 All-In-One InkJet...
I have a Canon ip 4300. Recently I had a paper jamb (81/2 X 11)
it maybe the sensers which tell the faults has moved out of position or wires loose
Jul 06, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Printer starts to grab paper then paper jambs.
Hi, Follow these steps:- 1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. 2.Turn off the printer. 3.Remove any paper trays. Inspect them for wrinkled or damaged paper. 4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. 5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. 6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly.The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. 7.If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. 8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. 9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Thanks! mannu_rakesh
Sep 09, 2009 | Brother HL-2170W Laser Printer
My HP Deskjet D1360 printer green light keep blinking.can't take printout.The machine does't get the paper inside. so send the solution
you have a paper jam
pull out the paper tray, check for the jam if all is well, open the printer, check under the printer cartridge, then the back
a little piece of paper will cause the jam
it is a good idea to use canned air to clean your printer, under the cartridge and the rollers on a regular basis (once a month)
Mar 01, 2009 | Computers & Internet
Hp 5940 - print has paper jamb - Nothing vissible checked & stripped machine of any minute paper particals. disconnected everything for 24 hours. Still maintains it has a paper jamb. Any suggestions...
open the door and remove catridge then check all that sure there is not any poapaper jam issue.
then refix catridge again.
also check in back side if u can there is not any paper jam.
Nov 15, 2008 | Office Equipment & Supplies
Hp d1320
go over these steps
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Sep 30, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper light says on.. wont reset after jam is cleared
We have a few of the HL-2070N's and I have seen this issue on a few of them. Usually it indicates one of several instances that can be found on Brothers website in the FAQ's about what does the LED indicate area.
The main solution I have found is that depending on where the paper jammed it has affected the drum/toner cartridge assembly somehow or another.
  • I recommend taking the Toner Cartridge out of the drum unit
  • clean the corona wire by moving the blue tab at the front of the drum unit back and forth several times
  • I have even used can air here to get it even better all around the drum unit not just at the corona wire area
  • After make sure all is clean put all back together
This has cleared up most all of my paper jam LED issues and allowed for further printing.
Mar 28, 2008 | Brother HL-2040 Laser Printer
Canon Imageclass D880 all-in-one
The area you are describing is the fuser exit rollers. Most likely the upper and lower rollers are worn out and the paper jammed there. You will need a technician with the background on repairing this machine to fix it. This is a major repair.
Jul 27, 2007 | Canon imageCLASS D880 All-In-One Laser...
Lexmark E460DW Mono Laser - 38ppm, 466MHz Processor, 1200 x 1200 dpi, 250 sheet input... Printer Logo
74 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
