Question about Samsung Oem Dc31-00054a Dc3100054a Drain Pump Motor Assembly
How do you replace samsung drain pump - Samsung Oem Dc31-00054a Dc3100054a Drain Pump Motor Assembly
DW80F800. What does 5E error code indicate?
Hello. Straight out of the service manual for your dishwasher...the 5E error comes from the low level switch not being detected within 3 minutes during the drain cycle...possible causes...clogged drain line, broken wire on the drain pump, defective drain pump, bad ECS, bad main board--in that order. Absolutely make sure there isn't something jammed in the drain pump that could slow it down or jam the impeller. Also, those drain brakes can be a real problem with mold/mildew gumming up the inside--once mold grows in these things, you MUST replace it--I've tried the cleaning route--it just comes back. I hope this helps you.
drain pump--DD81-01527A
brake--DD82-01111A
main control board--DD82-01139A
Oct 15, 2015 | Samsung Dishwashers
I need to find the reset button. It will not drain. This has happened before but I can't remember where the reset button is.
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
Jun 24, 2015 | Samsung Washing Machines
I have a Samsung 8kg top loader and had to change the drain pump. The new pump just runs constantly while the power is on.
The old drain pump has taken the control board out with it & it's now stuck in the drain pump cycle. You will need to replace the main pcb to fix this one.
Jun 15, 2015 | Samsung Washing Machines
What does samsung dishwasher error code se
SE (or 5E) on a Samsung DishWasher means Drain Error - Water not draining. Check the drain pump and drain hose for an obstruction; If that's okay, you will probably need to replace the ECS sensor.
Apr 21, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
Replaced drain pump, still won't drain
drain hose could be blocked have you checked ? or there could be a obstruction in the sump hose
Sep 27, 2012 | Samsung WF316BAC 3.79 cu.ft High...
Samsung WF209ANW front load washer -- ND error code. I cleaned debris filter and all hoses, however it still will not drain. How can I tell if the drain pump needs to be replaced? Is there a diagnostic...
Hello & Welcome to FixYa
ND error in your Samsung Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Sep 25, 2011 | Samsung WF328AA Front Load Washer
Samsung WF337AA Front load. How does it know it has not drained? Is there a sensor? Ours is working intermittently. It is draining but not spinning all the time. Sometimes we get a ND even though I can...
Make sure there is no foriegn objects in the tubes or drain pump. You might want to replace the drain pump and If it still has a problem, the main pcb. First check for loose wires around the main board and drain pump.
Nov 28, 2009 | Samsung WF337AA Front Load Washer
My Samsung duet washer is not draining properly and after awhile when it does not drain the message F02 shows on the console. It also does not spin even though it is showing it in the spin cycle.
It won't spin until all of the water is drained out of it. It probably needs the drain pump replaced. Take of the back cover and see if you can hear the pump hum. If you can and no water is coming out of the drain hose, remove the pump and check for obstruction. Alot of the time socks get stuck in the pump. If nothing is preventing the pump from turning, replace the pump.
Nov 26, 2009 | Samsung WF337AA Front Load Washer
It doesn't drain.
If not draining, remove pump and clean impellar compartment. Try and test motor electrically before you replace as it could have become damaged while trying to run it in a jabbed state.
Sep 25, 2009 | Samsung Washing Machines
Samsung Oem Dc31-00054a Dc3100054a Drain Pump Motor Assembly Logo
35 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
