Question about In-Sink-Erator InSinkErator Badger 5 1/2 HP Food Waste Disposer
Badger 5 leaking from body middle connection
I discovered that my Badger 5 is leaking from the flange on the body of the unit. There are long screws that connect the upper (sink) side to the lower side and tightening them didn't help. The leak only happens when the unit is running. Water starts bubbling out right where one of the long screws (visible on the outside of the unit) connects into the the bottom half. Is there a gasket that can be replaced or an easy fix? The unit is greater than 8 years old so I was thinking of getting a new unit.
  • In-Sink-Erator Master
  • 5,245 Answers
1) Copy following link for troubleshoot and parts resources, and manuals with warranty information:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
2) New unit would be best solution. And possibly cheapest solution. Otherwise you might be installing and un-installing more than once or twice ... which is fun if you have time, and other housemates don't mind kitchen project tools, water and mess.
3) If you can disassemble the disposal, you might be able to make your own gasket using kits and sealant from local auto parts .... assuming the metal was not mis-cast during manufacture and is warped so it never seals.
Posted on Dec 13, 2012
Water is seaping around the top but it is not coming from the main gasket .
Discovering the source of the water leak can be difficult ,but water leaks commonly occur near the roof sheathing.
Jan 04, 2018 | Amtrol Water Heaters
If I suddenly have no hot water and the lower element on my electric tank suddenly has a very minor leak coming from the element, could the two be related?
You should have about 10-16 ohms on the element screw head. Also check from one screw head to the tank body, there should be no short there. A leak there on the lower element tells me that it's your problem. I JUST changed an element yesterday that ohmed out at 14 ohms, and showed no short to the tank body. But I had 240 volts on the element when power was on. I changed the element and it fixed the problem.
Nov 14, 2016 | Rheem Water Heaters
Amtrol boiler mate bottom flange gasket leaking water
make sure bolts are tight, if they are then it may be time to change out the flange gasket
Apr 06, 2014 | Amtrol Water Heaters
Leaking drain valve
1) Copy following link:
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html#repair
2) You may find it is easier to put garden hose cap over dripping drain valve.
Screw very tight with channel locks.
3) Add comment and say what you discover
Feb 08, 2013 | Water Heaters
Cost to replace motor on a badger 5-1 garbage disposer
Yah --- if it is humming - usually means it is jammed -- check it out on the sides of the blades. If it is over 2years with heavy usage - get a new one
Nov 24, 2012 | In-Sink-Erator InSinkErator Badger 5 1/2...
HOW TO REPAIR A LEAKY INSINKERATOR HOT WATER DISPENSER...... Found the following at another website when looking for a solution to my leaky hot water dispenser. Worked great for me, so wanted to share the...
What if you back the temp down to say 165 or so would that not keep the plastic from frying?
Also does that model not sit ambient until hot water is needed and is not "hot" 24/7/365 as you
stated? Just wondering.
Feb 06, 2011 | Emerson Water Heaters
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
Leak in the bottom of insinkerator 1-81 near reset button there are two little flange looking things one is leaking rapidly when water is on
depending on the age it sounds like you may have to replace the unit,, insinkerator is the best on the market so when they leak it;s time for a new one ,, if not to old and under there warranty they will send some one to ifx it just call the 1-800 number on the unit
Jun 13, 2009 | Emerson Insinkerator 2.5 Gallon Water...
Slow leak drips from bottom of 4 year old model
Hi
Please try and remove the cap by turning it clockwise and counter clock wise to remove it. If it doesn't come off then empty the water dispenser and use glue to fix the leak. See this link to see which type of glue should be used--- Glue Usage
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Apr 07, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
In-Sink-Erator InSinkErator Badger 5 1/2 HP Food Waste Disposer Logo
124 people viewed this question
Top In-Sink-Erator Water Heaters Experts
Paul Carew
Gil Shultz
Are you an In-Sink-Erator Water Heater Expert? Answer questions, earn points and help others
