Question about American Standard Heating & Cooling
American standard heritage 12
I need a service manual. Wiring new condensor fan.
    Genius:
  • American Sta... Master
  • 1,033 Answers
Do you have 3 or 4 wires coming from the Motor?
Posted on Dec 13, 2012
4 Suggested Answers
SOURCE: NOT a problem--preventive maintenance is my goal.
By code, whoeve installed this brand new unit should
have left the manual with it. Check the electrical
control box or the fan compartment to see if a manual
is not in there
Posted on Feb 13, 2010
  • 117 Answers
SOURCE: Wiring
Maybe try calling Grainger or they might have a website online. Have you googled the brand of your thermostat? Often PDFs pop up with manuals.
Posted on Jul 14, 2010
icemelts
  • 246 Answers
SOURCE: 1 year old system 16
If everything (inside/outside units) is running 'constantly' and you are not getting any cooling there are several things that could be wrong, and I will list them below in the order I think most likely based on the limited knowledge I have about your problem.
1. Often customers will say 'everything' is running when in actuality everything is running with the exception of the 'compressor.' The reason being is that the compressor has an unique running noise which is not easily recognized by the customer. A serviceperson who works on Air Conditioners can pick it (the sound of the compressor) up - simply because they are accustomed to it and it is easily recognized. Therefore, I am unsure whether or not your compressor is running although I do think you inside and outside fan motors are running. All that being said - the fact that you are not getting cooling indicates to me that your compressor is either (A) not running or (B) the system is 'out & or very low' on refrigerant (which will cause the compressor to run very quiet and make it difficult for even an experienced serviceperson to hear it.
Often when encountering systems out of low on refrigerant I've had to actually feel the compressor
(with the system running) to determine whether or not the compressor was running. If you are mechanically inclined and want to determine if your compressor is running - I will just tell you to be very careful when putting your hands in and around electrical components.
One of the things I've done in the past when a little hesitant to actually touch the compressor (with system running) but still wanting to know if it (compressor) is running is to take a long screwdriver and hold the tip to the compressor - therefore being able to pick up the vibration of the compressor (which is out of gas or very low). If you do this and feel the vibration of the compressor and then know that it's running you have the infomation needed to understand that your system is either out of or very low on refrigerant.
If, however, you determine that the compressor 'is not' running I would bet that when you TURN THE SYSTEM OFF AND MAKE SURE ALL POWER IS OFF - and hold your hand on the compressor it will be very warm/very hot - which indicates that it has heated up and went 'off' on internal overload. You could still be experiencing the problem - of lack of refrigerant - because when the refrigerant level is low the compressor 'will' heat up.
However, is also possible (and more likely) that the compressor is 'off and hot' because it has broken down 'electrically' which can be caused by various factors - chief of which is - it is mechanically/electrically wore out and needs replacing. Note: it's also possible, although unlikely, that you have a bad 'run capacitor.' I would take a look at it (it's a gray or silver oblong shape electrical device with wires attached to it) and see if it's 'bulged' in any way - which is an obvious sign that it's bad. Barring a 'bulge' I would assume the capacitor is ok - which it probably is.
At this point and with the above indications - I would think you'd need an experienced serviceperson to look at your system.
2. But - 'it's also possible that when you actually turn the system off - MAKE SURE ALL POWER IS OFF -and feel of the compressor it "could be cool/cold' to the touch. If' that is the case - then I would look for a 'wire burnt off it's connection' (somewhere in the unit), bearing in mind that the obvious place for this to be will be on the compressor itself.
You will have wires running to the compressor and will be behind a little black plastic cover held on by a silver wire clamp. Remove the clamp - pull the plastic cover out - and examine the connections under it - looking for a wire that is burnt off. Move the wires a little because often the wire will be burnt off but it will not look like it - and by moving the wire you will see that it is not connected. If you find a wire burnt off - then you just need to get a new connector and connect it back on the wire and put the connector back on it's connection and you 'should' be fine.
A wire being burnt off a connection at the compressor 'could be' a sign of something seriously wrong with your system but 'usually' you can repair the wire and the unit will be ok. Maybe the connection had been 'loose' from the factory and finally burnt into or etc etc. But, as stated - to could be an indicator of something else. The only thing you can do is to repair it and hope for the best.
Note - obviously - you would want to have a 'wire burnt off' instead of all the other stuff, i.e. 'out or low' on refrigerant,' or a 'compressor mechanically/electrically wearing out.'
Hope this has helped.
Posted on Jun 10, 2011
I have been trying to 'activate' my new David Jones Heritage card without success is there a phone number I can call to assist with this process as the current site is hopeless!!
Store card
Need Assistance?
Call 1300 36 89 89
or credit card?
Need Assistance?
Call 1300 36 89 89
Card Member Services - David Jones
https://www.davidjones.com.au/Cardmember-Services
For full terms and conditions please see the David Jones American Express Cardmember Agreement. Cards are offered, issued and administered by American ...
David Jones Storecard
https://www.davidjones.com.au/David-Jones-Cards/David-Jones-Storecard The David Jones Storecard comes with your choice of reward options; David Jones Gift Card Rewards1 or Qantas Frequent Flyer2, and access to a range of ... David Jones Heritage card Google Search
Jun 24, 2017 | Cell Phones
Why does my American Standard heat pump compressor and condenser fan run when I have the thermostat set to emergency heat?
It's possible the "brain" thinks it can still supply some heat. Other wise there is a wiring problem or thermostat switch problem. Installed recently? Never used emergency heat before? What is your emergency heat type, gas or electric? Are you sure they are working. If not the "brain" senses and uses the only source available: heat pump. Thermostat? probably Honeywell? If so call Mfg customer service. Warranty on thermostat or heat pump? If so call customer service. Call your installer.
Feb 28, 2015 | American Standard Heating & Cooling
Standard reset
You are out of freon or the thermostat is broken sounds like
Jul 10, 2013 | American Standard Heating & Cooling
Noise very bad at outside unit new american standard ac
should not be that noisy. fan bracket loose or blade out of balance.
Sep 13, 2012 | American Standard Heating & Cooling
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
Heritage superfan model 4000hp fan does not work!
This fan has a unique dc motor and a proprietary controller. DO NOT USE A STANDARD CONTROLLER OR SWITCH. The controller is very rare and is no longer made or supported. The company was purchased by Casablanca Fans, but they offer no help.
May 03, 2010 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
NOT a problem--preventive maintenance is my goal. I kept my Payne heat pump (installed in 1985) humming nicely until this January. I only replaced it because of cost/efficiency issues ($$$) every summer....
is not in there
Feb 13, 2010 | American Standard WCZ036F Air Conditioner
Heat pump not cooling after wiring damage repaired.
Do you have the model number? This would help find the code
Aug 10, 2009 | American Standard Heating & Cooling
Heating & Cooling Logo
272 people viewed this question
Top American Standard Heating & Cooling Experts
Tim Whalen
Mack Baxter
ROCKIT957
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
